Thread: what IS this rattle?
    Jun 2006
    teeside
    Default what IS this rattle?
    got a loud metal on metal sound when i go over a bump
    defo not the new suspension, not my exhaust, but its a very light metal sound like ally on tin. now through doing diferent things with it i have discovered that if you pull the handbrake on slightly as you go over a bump there is no clunk! am i right in thinking the handbrake cable runs over the heatshield? is there any way the cable could be drooping and is sitting on the heatshield while driving and banging up an down when i hit a bump? this would then explain why it doesn,t do it when you pull the hanbrake on a bit and go over a bump.
    its in the dealers at the mo and i know in the morning they are just going to try and blame the non vx suspension and zorst for the rattle, but i have had these 2 items checked for play and know it defo isnt coming from these mods any ideas anyone? its only 8 months old so shouldn,t be dropping to bits yet .
    forget to say new discs and pads all round as well
    Jan 2006
    Skynet HQ EMEC#5
    Might be worth checking the nuts and washers that hold the heatshield in place.
    I had a big rattle, the tin shield had worn around the nuts, had to fit bigger diameter washers.
    Jun 2006
    teeside
    lets go and find out
    Regular Member signumT's Avatar
    grimsby
    had the same sort of problem with the signum when i had it and had the radiator bushes replaced pinging noise like a stone hitting the tyre and the handbrake cable adjusted was ok after that they also tightened all the caliper bolts
    Jun 2006
    teeside
    all sorted now rear pads rattling in the calipers
  1. DMF rattle
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2013, 13:31
  2. 2.2 with a rattle
    By MORGIE8153 in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:17
  3. Bad rattle!
    By heheshamon in forum Bodywork & Interior
    Last Post: 16th April 2010, 20:37
  4. A rattle at 70
    By Jezza181 in forum Engine & Drivetrain
    Last Post: 25th March 2009, 08:02
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
