Results 1 to 10 of 14
Thread: Vauxhall Cavalier ignition problems..
    Nov 2010
    Maidstone
    Default Vauxhall Cavalier ignition problems..
    Hope someone can help, just recently my dads had problems with his 95 cav ls, got stuck on the isle of white when something went wrong with the ignition barrel/switch. Strange thing is the key goes in, turns to 1, then to 2 with ignition lights on the dash and 3rd feels like something has jammed. Used to have a 10-15 degree turn to fire engine now it just doesnt do anything. Steering lock will come off, can be bump started but will not fire engine of the key. Could this be the switch or the barrel? Can anyone help?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like you need a new barrel fella common on the cavaliers
    scotland
    prob ignition switch , strip it out and try wi a screwdriver or something if it works the could be barrel but prob the ignition its self .
    Nov 2010
    Maidstone
    I always thought that is the barrel was shot the key wouldnt turn at all?
    scotland
    Quote Originally Posted by signum_rob View Post
    ok I read it turns until last position
    Nov 2010
    Maidstone
    Ye it turns untill fire up point but the key feels like its hit a wall, which makes me wonder if its a dodgy switch, dont want to buy both parts if its just one.
    Are you VXR Enough
    13 Post(s)
    take the wiring plug plug off the back of the barrel fella and insert a screw driver into the plug and turn see if that starts it
    Nov 2010
    Maidstone
    Dont suppose you know how the plug comes off?
    Are you VXR Enough
    13 Post(s)
    you have to take the steering wheel cowling off and you will see the wiring plug this plug has a tiny grub screw that you have to loosen and then pull the plug off. insert a scrrew driver into the plug and turn betcha the engine starts lol
    scotland
    you changed yer mind ! did you not say it was the barrel in your first post ??
  1. Replies: 6
    Last Post: 17th November 2012, 17:42
  2. Ebay Vauxhall Cavalier - Funny Description
    By Vectralicker in forum Comedy & Humour
    Last Post: 19th March 2012, 14:14
  3. Vauxhall Alarm Problems
    By 798EAT in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 21:02
  4. Total vauxhall problems - issue 108
    By Turbodave in forum General Chat
    Last Post: 16th March 2010, 22:51
  5. Vauxhall Cavalier Mk3 Drivers Side Door Mirror-Colour Coded
    By Vaux-Man-G in forum General items for sale
    Last Post: 28th December 2008, 17:10
vectra c ignition symptoms
