Thread: What gearbox on 06 3.0 v6 cdti???
    Aug 2009
    Ascot
    Default What gearbox on 06 3.0 v6 cdti???
    Hi,
    Looking at changing my gearbox fluid and wondering what gearbox I would have in my 06 vectra Sri cdti auto.
    Also what fluid should I use
    Nick
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    AF40 gearbox, about 7L of oil, about 3L per oil change. Type of oil used: ATF AW-1
    http://www.opel-infos.de/getriebe/af40.html
    Aug 2009
    Ascot
    Thank you , is it quite easy to change?
    As in do I drain and re fill or do I need to try and flush it put
    Nick
    just drain and refill
    theres a how 2 in the how 2 section
    just remember you need to replace the fill and drain plug when you do it , they cost about £7 from delaers for both
    also make sure you can undo the fill plug before draining the oil out !!!!!
    when refilling ONLY put 2.4 litres in
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by marktaylor View Post
    Mate...his is an automatic
    oops didnt read it properly , it was 7am !!!
  1. 1.9 cdti 120 how much oil should go in the M32 gearbox?
    By v33tra in forum Engine & Drivetrain
    Last Post: 9th February 2011, 01:18
  2. what gearbox does my cdti 150 have?
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2009, 17:10
  3. What gearbox in a 1.9 CDTI ?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2007, 00:21
