Thread: ABS Wiring
    Regular Member F33F33's Avatar
    Nov 2009
    Preston
    Vehicle : Insignia
    Trim : SRi VX-Line RED
    Engine : 2.0CDTi
    Year : 2012
    Default ABS Wiring
    Placing this here as it will gather most attention due to its urgency!
    Car in booked in for ABS fixing tomorrow (again) as the ABS light is on and MOT was due... April. Only checked as I needed TAX as I thought it was July.
    I have previously had my ABS light on after it came on randomly back in Feb, Tech2 and OP COM pointed to the front ABS hub ("Open circuit on OSF ABS hub") So I went out and got a nice new one and had it fitted just to find that the problem was still there and comes back after clearing, was told could be wiring or ECU, but as my inlet needed replacing at the same time I didn't bother sorting it straight away and left it. Skip forward to April, we had a nice hot few days and after taking a new pics of my car I noticed my ABS light wasnt lit anymore, WOO .
    3 Weeks later while driving back from MK I had my cruise control on pottering along at 55-60mph, then the heavy rain that you cant see 15ft ahead of you came in, after a few mins my car started chugging as if the CC was cutting in and out, and then after a few mins again my ABS light popped back on where it has stayed ever since.
    So car is booked in the morning for ABS "fixing" if they can... can it be done by any garage or does it have to be a proper auto electrician? MOT will be done after it, and then off to the PO for some TAX.
    Prob looking at about £300-500 depending on what else is wrong with it come MOT time.
    WGAF#5
    the ABS issue should be abel to be sorted by any competant mechanic ..
    either reading the wiring to establish if there are any shorts or resistance on the wiring ... or then esptablishing if there is a fault on the hub / sensor or ecu ..
    and they should be cheaper than an auto electrician who is more specialised
    Nov 2009
    Preston
    Vehicle : Insignia
    Engine : 2.0CDTi
    Year : 2012
    So much for urgency! Only got 2 views!
    Thanks for the reply Dez, doesn't fill me with much confidence though! If they say new ECU (which I doubt) I will cry.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    you need to be a woman to get more replies m8
    I looked but couldn't offer any advice.. sorry
    Nov 2009
    Preston
    Vehicle : Insignia
    Engine : 2.0CDTi
    Year : 2012
    ABS is fixed, or so they say! Failed MOT on a broken spring and a tyre!
    Not to bad
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by F33F33 View Post
    Not to bad
    What's was the fix??
    Nov 2009
    Preston
    Vehicle : Insignia
    Engine : 2.0CDTi
    Year : 2012
    Just a bare wire it seems in the arch, but I figured that anyhow
    Sucks about the spring, i'd rather get proper springs but I dont have the time nor money to get them as I need a valid MOT to get TAX! I hope I get an SRi spring and not a normal one
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
