Thread: Coolant Problem
    Apr 2011
    Berkshire
    Default Coolant Problem
    I have changed the turbo on my z20net, so drained all the coolant out of the system. It has been stood still for a couple days while turbo has been off the car being fixed.
    I have put all back together and put some coolant in, though it only let me put in about 2.5 litres though i removed a lot more.
    I started car up and it got up to about 93 degrees and I have heaters on full blast on hot and there is no heat coming from them, and the water doesn't seem to be going down.
    Any ideas?
    Also when should the fan kick in as it hasn't yet
    Apr 2011
    Berkshire
    All sorted was just an air block
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    was just going to say you need to hand pump the coolant pipes to pump the coolant around after you have done a job like that.
    Apr 2011
    Berkshire
    yeah that is what I have done, cheers anyway
  1. coolant problem persists
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2013, 12:02
  2. signum 3.0v6 elite coolant problem?
    By carmadcarl in forum Engine & Drivetrain
    Last Post: 25th August 2011, 22:57
  3. possible coolant problem ?
    By SRI Chris in forum Engine & Drivetrain
    Last Post: 19th July 2009, 19:19
  4. Coolant Problem
    By ilaing in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2007, 19:58
