Thread: towbar
    Regular Member tgbo's Avatar
    Nov 2010
    stirling
    Default towbar
    hi all can anyone recommend a detachable towbar for the signum need one soon and I prefer the detachables seen a few different style/fittings and just looking for some guidance cheers
    Regular Member RhayaderSax's Avatar
    Rhayader
    I had a Westfalia swan neck on my Signum. If you tow a caravan & use a "leaf spring" type stabiliser, you can bolt the fixing bracket to it.
    Nov 2010
    stirling
    cheers mate westfilia is what I was looking at along with wittier thanks for the added info on the stabiliser as I have access to two caravans one with Aklo and a older hitch which needs the stabiliser 
    Regular Member coooky's Avatar
    May 2011
    washington
    if you dont already know
    you will need an alko ball for the car they look like a mushroom as the pads grip under the rim a standard ball will smash the side off the alko
    i know this as the father inlaw towed his caravan on a standard ball and it jammed and the pressure smashed the side plate off
    Regular Member V6 Nell's Avatar
    Staffordshire
    I have a detachable Witter Quantum on mine. Can't fault it.
    Rhayader
    Quote Originally Posted by coooky View Post
    ...you will need an alko ball for the car...
    Not necessarily...
    Quote Originally Posted by AL-KO
    Towballs must meet Directive EC 94/20 (Din 47058)
    The diameter of the ball must be 50mm (+0/-39mm)
    There must be a minimum of 60mm depth from the centre of the towball to the base of the neck. This is for AL-KO stabilisers as apposed to coupling
    heads.
    There must be enough clearance between the centre of the ball and the base of the neck to enable the stabiliser to perform a 25° axial rotation movement.
    A standard flange (fixed) towball may not meet the criteria but you should be OK with a removable "swan-neck" type. The full Al-ko Kober data sheet can be found HERE
  1. towbar
    Last Post: 17th March 2011, 10:49
  2. Which Towbar?
    By humphshumphs in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 21:39
  3. towbar will it fit?
    By xyy81t in forum The 'Off Topic' room
    Last Post: 25th March 2009, 18:50
  4. Towbar help please
    By Robclowes in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 16:56
  5. towbar help
    Last Post: 12th April 2008, 23:11
