Results 1 to 10 of 14
Thread: boost gauge.......
    Oct 2006
    Glasgow
    Default boost gauge.......
    green growler..... i'm a bit of a novice when it comes to the actual mechanics of an engie but i could certainly deal with the interior parts of this mod. Could you do me a quick, basic how to on this mod, i.e where to connect it to in the engie bay etc........
    Would really appreciate it mate.
    Hertfordshire
    Hi m8, welcome to the site.
    These pic's give you the best idea of how I done mine.
    You need to tap into a hose that is under boost pressure, the top one to the right of the engine is probably the best place.
    I done mine underneath so it is less obvious.
    You should get a connector in the kit, if not, the supplier of the gauge should be able to supply one as well.
    You just drill/cut a hole in the hose and put the connector in, then run your tapped hose of it.
    Most boost gauges have the boost sensor built into them, so the tube you tapped off needs to run to the back of the gauge.
    But mine has a remote sensor so my tube only runs to this, and then a wire runs to the back of the gauge, I have mounted my sensor on the side of the battery box, as you can see here.
    Hope this helps.
    Regular Member Harry's Avatar
    Uxbridge, London
    damn DTi owners being able to tap into the boost!!
    Hertfordshire
    Lol, why, cant you guys ???
    Uxbridge, London
    i dunno......don't you remember at Track 'n' Road they couldn't tap into the the v6 diesels or Deans.
    although Nutron has done it.
    Hertfordshire
    Oh right, see what you mean, they had the same problem on mine, which is why I could just use the T-piece that came in the kit, tis why I have tapped directly into a boost hose, cant see any reason why that would work on ANY turbo motor.
    Uxbridge, London
    i couldn't remember whether they had the same trouble with yours, i thought it was just the cdti's giving 'em grief.
    Hertfordshire
    Nope, they got a reading off the petrol (D's) but I don't think they could get a boost reading off any of the diesels.
    Oct 2006
    Glasgow
    excellent - that should help a lot.
    I may be back if i get stuck.
    cheers mate
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    iirc didnt Nutron find a nice place to tap off of for his mega-boost gauge?
  1. boost gauge
    By Swedge in forum Engine & Drivetrain
    Last Post: 15th November 2012, 00:53
  2. boost gauge
    Last Post: 24th March 2012, 12:25
  3. Boost gauge help!!!!!!!!
    By tomo41 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2011, 17:36
  4. boost gauge
    By icetrix in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2007, 21:01
