Results 1 to 10 of 17
Thread: This site saved me £2160
    Jul 2010
    Wellingborough
    Thumbs up This site saved me £2160
    Hi All
    I would like to say thanks to this Forum you guys have manged to save me £2180.00.
    My Signum Cdti 150 04 plate 137,000 miles broke down last Monday on the M25 whilst on my way to Gatwick Airport. before car stopped the Spanner light came on Large amount of black smoke came out of the exhaust and car smelt of fumes.
    AA called out recover car to local garage after AA man cleaned out EGR Valve. Pressing accelator would rev to 2k but no more car taken to local approved V dealer.
    Was told the following day by dealer the following was required.
    1) New DPF
    2) New Inlet Manifold
    3) New EGR valve
    5) Intercooler Leaking
    4) Regen required total bill £2260.00
    After stating the car is not worth spending that sort of money on I decided to travel back to the Garage concerned and pick the car up I was able to drive the car back 120 miles at a max speed of 50 mph, driving through London was not a problem at that speed.
    Anyway after reading this forum I have learnt a lot and manged to spend £80.00 and my car is as good as new. This is what I did.
    1) Removed EGR Valve Clean it up and then cycled the valve by applying power to ensure it moved freely. after about twenty cycles and some light oil the valave is as good as new. refitted saving £135.00
    2) DPF removed Exhaust system and cleaned the DPF system using caustic soda spent the day cleaning this out. Loads of crap came out. The intresting thing was when I removed the DPF only 1 Stud of the Three studs was ok the other two studs had been sheared off. I then realised what I believe might have happend. the DPF got blocked which caused enhough pressure to blow past the joint and make the metal gasket flap making a odd sound at various driving conditions. ( I believ this is what the garage thought was the intercooler leaking....but I could be wrong). I drilled the broken studs out and fitted 8mm bolts in place used Exhasut paste and bolted joint up. Cleaning this and the repair Svaing £920.00 so i'm told....
    3) Refitted the inlet swirl bar using washers as described on this site working correctly. saving £400.00
    4) Next using 10k boost to clean inlet out again following the instructions on this site cleaned inlet Manifold out.
    Labour costs and Vat I was quoted £2260.00, I undertsnad my cost of course in time was two days but all I have is a trolley jack and bunch of hand tools...... no computer OBD2 op com thingy which I am now thinking of buying.
    Result my car just went back to Gatwick Airport to pick up the passengers I took down last week.....54.5 mpg I've never had 54.5mpg I've only ever seen 46-47mpg on a run or 40 around town.
    The car picks up great I just need to regen not sure how you do that yet but sure I find this on site somewhere.
    My car is normally used to travel to th estation and back each day, this does not do this type of engine any good it needs frequest long runs to clear it out.
    BUT I WOULD LIKE TO SAY I TIP MY HAT TO THIS SITE and its members, I have a feeling that the Garage concerned was more interested in selling me another car rather than fixing my car and picking up a bargin themselves.
    Sorry if I hi jacked this thread but I just wantted you all to know.
    One happy Signum owner
    Hats off to this site for saving my car
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Nice one
    Sep 2009
    Glasgow
    regen drive at 70 mph in 3rd gear for a while heat that baby up, you'll know when the regen starts change to 6 th gear and make sure you drive as high revs as you can till it completes.
    Jul 2010
    Wellingborough
    confused Regen
    Hi Thanks how will i know regen is running working and how will I know when it completes?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    great news mate this site is great for all kinds of helpful tips
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    instant consumption on the on board computer will increase and the exhaust will likely be glowing
    Jul 2010
    Wellingborough
    Question
    Thanks saved a trip to the bank manager, I've owned the car since 2006 it is a very reliable car just needs looking after now and again, I want to look at the fuel filter, another weeked job.
    It would be interesting to see a running cost of how much this site has saved people..... could this be a start of a running pole?
    Jul 2010
    Wellingborough
    Quote Originally Posted by Grumpy1954 View Post
    Thanks for reply Instant consumption increase by how much.....Exhaust glowing is that the tail pipe....will it be glowing white or red?
    Jan 2010
    glasgow
    op-com may let you do a regen
    Jul 2010
    Wellingborough
    op com which is recommended.....and price...where to purchase.
  1. Can this be saved?
    By leeoliver2011 in forum Styling
    Last Post: 21st April 2012, 16:34
  2. How much do you reckon I saved myself??
    By Z28 in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 00:27
  3. saved a lot of worry
    By johnkarl in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 12:03
  4. saved £80
    By neverlandandy in forum General Chat
    Last Post: 15th August 2008, 21:38
  5. Saved £40 today.....
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2007, 02:19
