Results 1 to 10 of 23
Thread: Vectra c 3.0 cdti ( loss of power )
    Regular Member dshelton999's Avatar
    May 2011
    manchester
    Angry Vectra c 3.0 cdti ( loss of power )
    Ok hi to all......
    I took my car for its MOT 2 weeks ago which gladley it passed
    On the way home i noticed a slight difference in performance but nothing major. I then went out an hour later and had a car full, its then that i noticed that something was really wrong.
    It would creep up to speed but the moment i put my foot down it would lose power and not want to go anywhere. The next day i went for a road test to try an get a feel for what was happening and i noticed that the turbo seems to be working correctly as i can hear it whiring up but no power. I have bin through the forum an tried most things that are recomended e.g (Cleaning EGR, Cleaning air intake manifold, blocking off EGR etc)
    I took it to a mechanic on sat who plugged it into his laptop using opcom software, there were no fault codes only the ones that i had caused by messing an pulling off random plugs with the engine still running. In the end he put it down to the bosch air intake sensor next to the air filter box. Which in all honesty i dont think it is, he then ran off with my last £40.
    Tonight i took the car out for a long run 50 mile all round trip, i have noticed that when maintaining a costant speed (70mph) its like the car has got its own heart beat, it struggles for 5 seconds like some kind of flutter then gets a little power for 1.5 seconds. It seems to do this for the whole journey. and this is all around 2000 revs.
    If anyone has any answers i would be very greatful for your replies
    Kind regards
    Daniel
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved
    Irmscher Insignia CDTI 130
    May 2011
    manchester
    sorry, forgot to mention that it seems to be using more fuel to
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    SCV's
    Basically the engine is asking for a certain pressure of fuel and the pump cant keep up.. If you pussyfoot the car whilst driving and not slam the accelerator down hard it'll drive ok....
    Its a pump out to replace the suction control valves.... You'll need to verify this first though (due to it not being a cheap job and also I may be wrong)
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by plasma View Post
    SCV's
    It can also be a blocked fuel filter, contaminated fuel...don't jump to SCV's immediately. And it's not a pump out job That's what the Opel dealer that did mine said (not needed the job done in the end lol fool)
    My car was presenting the same symptoms last year. Traced it down to water in diesel...
    My old 3.0 had a blocked fuel filter, resulting in similar symptoms
    In both cases fuel pressure went right down...demand was, let's say, 150mPa, actual pressure was 15mPa...
    SCV's
    Sadly I tend to agree
    You can be gentle with the gas pedal, but it will get worse
    You can also use diesel fuel pump cleaner (not injector cleaner)
    Eventually the affected SCV will become totally blocked and then the engine will go into safe mode and shut down, but by that stage you will be lucky if you can drive at or above 30mph
    May 2011
    manchester
    Thanks for the replies its nice to know there are people out there willing to help.
    i have tried injector cleaner in my tank and also filled up yesterday and added 2 stroke, which is mentioned in another post. problem is still there.
    I will get new filter in the morning and change that, hopefully it may help
    I have a friend at arnold clark who lets me have parts for trade, got quoted £25 for each SCV earlier today but that was a rough price because he couldnt get my reg to work on computer, Going to phone them back tomorrow with chassis no.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by dshelton999 View Post
    Injector cleaner and 2-stroke didn't help with my issue. I used a water remover additive, which helped. Try that, when the tank is empty and range is at 0...add that and drive for another 10-20miles. Fill up again and let's hope it works
    May 2011
    manchester
    what kind of water addative do you recomend ?? (make, were to buy?)
    Thanks!
    Daniel
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I used STP Water Remover
  1. vectra 3.0 sri cdti: 75 % power loss. No inection
    By mtqn in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:47
  2. Power Loss Vectra V6 3.0 CDTI
    By renwich in forum Y & Z30DT Specific
    Last Post: 7th September 2011, 22:52
  3. Loss of power diagnosis Vectra 1.9 CDti
    By MT82LFC in forum Engine & Drivetrain
    Last Post: 17th June 2011, 20:58
  4. Help with Vectra CDTI SRI 150 - Car loss of power
    By dan912 in forum Troubleshooting
    Last Post: 27th May 2011, 08:59
  5. Vectra CDTi 150 - Loss of Power
    By Chappers. in forum Engine & Drivetrain
    Last Post: 4th January 2011, 23:37
vectra 3.0 cdti loss of power
vectra c 3.0cdti loss of power
opel vectra 3.0 cdti lose power
vectra cdti 3.0 loss of power
2 stroke in cdti
