Results 1 to 10 of 14
Thread: Supplementary Question on Changing Front Springs
    Regular Member Signumv6man's Avatar
    Suffolk
    Trim : Elite Auto
    Engine : 2.8 V6 Turbo
    Wink Supplementary Question on Changing Front Springs
    And specifically about undoing the top nut on each strut:
    I have got to do this this weekend and never done Veccy/Siggy springs before, so I want to be prepared.
    There are a number of methods people seem to use to undo the top nut of each strut, which appears to be screwed onto a rod that has a female Torx head.
    2 questions:
    1) Am I right in assuming that the the Torx head on the rod is to simply stop the rod from turning when you do up/undo the nut ?
    2) In which case how can you get torque wrench on at same time as Torx bit to torque it up ?
    Sorry if these seem dumb questions but I hate not knowing, especially when car is in bits and you're in a swearing frenzy !
    East Midlands
    No need to torque it up mate,just use a swan neck spanner,hold the centre rod with the torx bit and do it up as far as the nut will go,ther you go duck bang tidy.
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    1) Yes...
    2) Using vortex sockets to undo it, but not sure of a way to torque it back up, normally its till you bust a blood vessal, cave the front wing in by leaning against it or when your eyes feel like they're gonna pop out.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I used power tools to change mine.. didnt hold on the nut..
    the car on ground, the tools on until free, then removed the asembly, and undone the last bit.
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    took both mine out when changing top strut bearings. whipped them up to local mechanic.
    He used impact wrench to get them off and on. job done. Had to use spring clamps mind. make sure there on properly though. Nasty accident waiting to happen if there not...
    Regular Member hagga's Avatar
    kingswinford
    3 easiest ways i've found to do this is either... car sitting on deck and use impact wrench.....use M14(i think) spark plug socket(has flats for spanner) and allen key/torx key down middle of it.... take off complete strut and take them to garage (nominal 'drink' donation)
    Quote Originally Posted by MURDO View Post
    that too
    Suffolk
    Trim : Elite Auto
    Red face
    Thanks fellas, am ready to have a go !
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    You not seen the Pre-Billing workshop meet happening at Haverhill? May be a chance to do your springs?
    WGAF#5
    especially as you in Bury
    Suffolk
    Trim : Elite Auto
    Default Did the job yesterday
    Thanks once again fellas - did the job yesterday (both springs) and owing to the information on here and hence being prepared it was dead simple !!
    My eventual method for dealing with the strut top nut was:
    1) Crack the nut with the strut still on the car.
    2) When strut off car and spring compressed - used a spark plug socket and adjustable spanner with torx key through the middle held with mole grips - both were easy to undo.
    3) Re-assemble and screwed nut back on all the way off the car then full torque setting (100NM) once strut back on the car.
    I also noticed that the original springs have a short length of protective PVC tubing over the first 150mm or so of spring length, I reclaimed this and fitted it to the replacement springs, which didn't have it.
    If any further breakages though I will be looking for better quality aftermarket replacements.
    Steve C (signumv6man)
  1. Spanner for Changing Front Shocks/Springs
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 21:21
  2. Changing springs do i need to change anything else?
    By aerodynamic18 in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 22:34
  3. changing front springs, price?
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 2nd September 2009, 20:11
  4. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  5. changing springs
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 22:45
