Results 1 to 10 of 17
Thread: Fuel light puzzler
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    Default Fuel light puzzler
    Quick question guys, On the Vecci C when I'm running low on fuel my Info display comes up with a picture of a petrol pump and says low fuel.
    What I'm wondering - is there a symbol that lights up on the dash to tell you when your low or is it just on the info display. I'm not sure if I trust the trip comp, I know there no always accurate.
    Any advice would help.
    Regular Member Harry's Avatar
    Uxbridge, London
    you'll get a light come up on the dash aswell.
    although the warning on the display used to come at exactly the same time as the one on the dash - at 31 miles left, now they're a little bit apart.
    the symbol on the dash will come up and when that starts to flash you've got around 5-7 miles left. The symbol will come on permanent at around 30 miles left.
    Ayrshire, Scotland
    I've been down to 23 before and I've never had a symbol light up on the dash,
    think I need to get this checked.
    Uxbridge, London
    yup....sounds like it needs checking, might be something trivial.
    Doncaster
    When the range shows zero, roughly how many miles would actually be left in the tank.
    Is there a reserve or should the range figure be taken as gospel.
    I've have my range down to 2 miles and I though I had more than that left - if I'd only had 2 I'd have been right worried!!!!
    Uxbridge, London
    i've seen it show that low and yet when i filled up i only had to put in 56ish litres, so still 4 litres left.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    iv'e had it down to 3 miles left when i filled it it took 56 ltrs so i had around 4 ltrs left.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I think I'm correct in saying...
    The light on the dash goes off volume of liquid left in the tank so will come on when the physical amount of fuel reaches a set limit (although mine is sometimes slow to respond)
    The Info display warning is based on your current average fuel consumption (which is taken over the last so many (15 I seem to remember but could be wrong) miles) so if you have been thrashing it like a rally driver for the past few miles it may tell you that three gallons will only get you 30 miles ... the dash light would then come on when you had say 10 miles left (would be one gallon in my example).
    Hope this makes sense ... please note figures given are not exact but the manual should shed some light.
    Dave
    Jul 2006
    Cheshire
    For clarity here is what the manual says about the average fuel consumption:
    The range is calculated from the current
    contents of the fuel tank and the average
    consumption over the last 12 to 20 miles
    (20 to 30 km) of the journey.
    The range updates automatically after a
    brief delay a fter the vehicle has been
    refuelled.
    Sunny UK
    Quote Originally Posted by ukanalyst
    Dave
    Hi
    So in theory its best to go off the light on the dash?
    Ta
    Johny
  1. When fuel light comes on, how much fuel is left?
    By inchy1981 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2012, 23:32
  2. fuel light
    By felix_19 in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2012, 15:37
  3. puzzler
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 10th March 2009, 22:21
  4. Fuel Low Light
    By IA76 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2008, 11:01
  5. Fuel Light
    By Higgins in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2007, 21:06
