Thread: V6 CDTi Oil Filter Housing problem
    Stoke on Trent
    Default V6 CDTi Oil Filter Housing problem
    HI Folks,
    Was in the process of changing my oil on my 2004 V6 CDTi this weekend. Sump plug came undone no problem and the oil drained out nicely.
    When I came to undo the Oil filter housing drain plug, it was INCREDIBLY tight, obviously the previous owner/garage has tightened it way above the torque that was specified.
    To cut a long story short, I got the plug out, but 90% of the thread came with the plug! DOH!
    My question is, can I get just the base 'cap' from vauxhall? or am i looking at a whole new housing?
    Bristol
    Quote Originally Posted by smitd004 View Post
    HI Folks,
    You can buy just the bottom housing part no 97229224 . I think it may have to come from germany . you couldtry saab daeler or renault As they have the same engine fitted in their 3.0 DTI.
    Bristol
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Or you could try local garage or engine place and get a helicoil thread insert placed in. Will prob cost about 20 quid for them to do it.
    I did same thing with mine just haven't got around to Gettin insert yet
    Stoke on Trent
    Good point!
    I'll check with my local stealership first to see if its not too unreasonable for a piece of housing.
    Failing that... I'll get it re-tapped!
  1. Oil filter housing 1.9 CDTI
    By hairymark in forum Engine & Drivetrain
    Last Post: 27th December 2012, 12:02
  2. 1.9 cdti fuel filter housing
    By jc2k5 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 13:00
  3. Location of fuel filter housing 1.9 CDTi
    By bennettboy in forum Engine & Drivetrain
    Last Post: 1st October 2008, 23:15
how to service a vectra c v6 cdti oil filter
vectra v6 cdti problems
Vectra v6 diesel oil filter cannister tool for sale
how to remove oil filter vectra c v6 cdti
oil filter removal tool vectra cdti
