Thread: Parrot MKi9100 are they easy to fit ?
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Parrot MKi9100 are they easy to fit ?
    I was going to buy one of these and fit it my self but has anyone fitted this one are they ok and easy to fit. Went to Halfords to get a price and they want on top of unit price £24.99 for extra lead and £25 for fitting.
    Do I need extra lead my unit is the CCR 2006 4 disc unit in a 2004 car.
    Any help would be great thanks.
    WGAF#5
    you need the SOT lead for the different connection type on the rear of the vx head unit to fit the wiring from the Parrot kit ...
    should take roughly 45 mins-1 hour to fit yourself
    pretty easy to do ....
    permanant live from the Cigrette lighter ... and away you go
    Jan 2008
    Irthlingborough
    Cheers for that will have a search for sot lead and give it a go.
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    simple i just fitted my mki9200 (well ill be taking it out now the cars scrap) but really easy
    no you dont , the ccr 2006 doesnt need a different lead to fit a parrot , as i have just fitted one to mine all you have to do is seperate the existing block into 3 parts so it will fit in the parrot harness ( hell understand when he sees it )
    also strangely didnt need to get a live from cig lighter , just swapped the 2 power leads over and it worked
    word of warning though make sure you fully test it before refitting stereo as first time i di mine i had the mute lead on the wrong connector and whenever i finished using the parrot the stereo came back on at ear bleeding levels !!!!!
    Jun 2011
    Basingstoke
    any problems running wires from parrot unit to mic ?
    Im going to get one myself but am put off the install if im honest.
    Where is best to locate the unit ?
    Jan 2008
    Irthlingborough
    Cheers for that Mark will have a go this weekend.
    Jan 2008
    Irthlingborough
    Cheers again Mark installed today and you were right didn't need the extra SOT lead just cut the 1 blue block into 3 one for power one for speakers and one for the steering controls and display.
    Not much room to move but very easy to fit
    Didn't change over the power orange and red works ok as is and see what you mean about the mute wire tryed in number 2 my ears bleeding after the radio came back in so used number 3 mute all working great.
    just need to update in the morning when light again.
    Put ipod wires in glove box for now so hope when the iphone is pluged in inside the glove box I can get a good reception as phone not great signal strenth.
    Quote Originally Posted by jammin31 View Post
    right its easy to run the wires to the mic , i installed mine next to the front interior light
    all i did was remove glove box and passenger a pillar cover
    run cable under dash and up a pillar cover then tucked it along edge of the headlining at the screen
    removed interior light and fed cable throught there
    refitted al the bits and jobs a goodun
    i located all the parrot boxes behind the heater control panel
    its an easy install
    good to hear nath
    ive run the iphone wires under the gear stick and drinks holder and cut a hold in the cubby hole under the arm rest so can hide it if i want to
    Jul 2011
    devon
    Doing this this weekend, i don't suppose you took any pics mark?
  1. Parrot MKi9100
    By Homer in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 18:10
  2. Parrot Mki9100 & Center speaker
    By iani in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2011, 20:13
  3. How many phone simultaneously connected to Parrot MKi9100
    By Danny-solar in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2010, 13:39
  4. PARROT MKi9100 - NO POWER HELP
    By typecastboy in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2010, 09:41
  5. Parrot Mki9100
    By johnynoi in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 21:44
