Results 1 to 3 of 3
Thread: Spanner Light and Error Code P1109
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Spanner Light and Error Code P1109
    The spanner light stayed on when you switch the ignition on but it should go out, start the engine and within 3-5 secs it goes out.
    Had this issue on 2 previous occassions and it turned out to be glow plugs, off I go to VX, the plugged it in and was stored code P1109 BUT not present which I believe is the swirl valve.
    VX Technician did a check on the swirl valve and operated manually whilst engine was off and reported it was OK.
    Any ideas why this would be stored but not present?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    anybody ...
    Jul 2010
    Waterford, Ireland
    Quote Originally Posted by Sebastian B View Post
    Could be airflow meter?
  1. P1109 Error Code
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:49
  2. spanner light but no error code
    By danno91 in forum Engine & Drivetrain
    Last Post: 12th October 2011, 19:20
  3. spanner light with no code again
    By iasha in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 16:41
  4. spanner light with no code again
    Last Post: 1st July 2011, 06:55
  5. Spanner light; error code 'Preheat delay fault'
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 24th April 2009, 16:33
