Thread: Engine management light & tech 2
    Aug 2009
    Ascot
    Default Engine management light & tech 2
    Hi,
    2 questions for those that can help.
    I have a 3.0 v6 diesel Sri and every so often it goes into limp mode but no light!?!? Is this normal? The engine management light does not even come on when I flick the ignition on!!!
    It's an auto and at about 80 mph it losses power as if it is changing gear and then no turbo ( limp mode ) then if I turn ignition On and off it is back to normal
    Any ideas?
    Nick
    Jul 2009
    The Rift, Cardiff
    It's possible that someone has put a bit of black tape over the light. I'm sure I've read of a couple of people on this site have had it happen to them. You night need to dismantle the clocks to check or possibly shine a torch in. It should be lit with ignition on and normally go out when you start the engine. I'm sure the symptoms your describing should put the light on too.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Nick you could have just a split vacuum hose or intercooler hose , what does she sound like when running any whstling noises or signs of oil leaking around your hose connection,s
    and still loving it
    Aug 2009
    Ascot
    Does anyone know where on a facelift dashboard the light should come on???
    Gonna go have a look around the car now
    Nick
    Engine : 2.0DTi
    Mileage : 73350
    Nick ,
    the car/spanner light is in between your clocks .
    pm being sent
    and still loving it
    Jul 2009
    The Rift, Cardiff
    The eml is in the bottom right corner, under the fuel gauge.
    Aug 2009
    Ascot
    In-between clocks or bottom right?
    It is a facelift version
    Nick
    Engine : 2.0DTi
    Mileage : 73350
    Nick the eml light will be bottom right , shaped like an engine outline would normally come on once ignition is switched on but engine not cranked over.
    I will show you when you get here .
    and still loving it
    Jul 2009
    The Rift, Cardiff
    as above the eml is bottom right and as bob said the car & spanner light, which usually comes on with limp mode, is in the clocks.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
