Results 1 to 10 of 11
Thread: Vectra alarms
    Regular Member mycarsavectra's Avatar
    Oct 2006
    Fife, Scotland
    Default Vectra alarms
    Hi guys, my alarm goes off at times for no reason and this seems to occur when the weather is hot and the inside of the car warms up in the sun, it's a bog standard alarm fitted to my Vectra, does anyone know if there is there any way to adjust it or make it less sensitive?
    Cheers in advance.
    Regular Member Harry's Avatar
    Uxbridge, London
    might sounds daft but you may have a fly or something inside the cabin that triggers the motion sensors.
    has it happened recently?? if so, then scotland must be having a freak spell of sun and i think i'll be moving from wet london!
    try pressing the button on the dash that disables the internal sensors, but i wouldn't suggest making a habit of it though. if you can predict when its going to happen then try, at least you can start eliminating some sources of the problem.
    Oct 2006
    Fife, Scotland
    ...No flies up here mate, the spiders eat them all, I'll try your Idea about the sensors but can I disable them then lock the car though?
    Cheers mate.
    Quote Originally Posted by mycarsavectra
    Cheers mate.
    Yes matey you can. There's a button to the right of the stereo head unit with what looks like a man running away. Before you get out of the car, press this button and then get out and lock the car in the usual way.
    This button simply disables the internal movement sensors; the rest of the alarm system works as normal.
    HTH.
    Oct 2006
    Fife, Scotland
    Magic guys, thanks for your help.
    Uxbridge, London
    hope it helps - otherwise its a visit down to your local dealers
    Uxbridge, London
    i've just had a thought....maybe the spider that lives in everyones wing mirror has finally found a way of getting through the mirror assembly and into the cabin and is finding yet another way to p1ss you off!!!
    Oct 2006
    Fife, Scotland
    Quote Originally Posted by Harry
    Gawd almighty...have you got a spider in your mirror too! where do they come from that's what I want to know....you wash the motor and a couple of hours later the damn cobwebs are back on the mirror again!!
    Uxbridge, London
    luckily i'm spider free - the only way i could get rid was to keep breaking the web, sooner or later they'll run out of food and move on!!
    it's a nightmare having them, makes the car look uncared for!
    Mileage : 000
    Try driving faster, the spider,s will not be able to keep up with you then,
  1. Aftermarket alarms
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2009, 20:58
  2. Sensitive Vectra Alarms
    By monkeytwo in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2009, 18:46
  3. Canbus car alarms.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2006, 10:09
  4. alarms
    By donna in forum General Chat
    Last Post: 18th October 2006, 23:38
  5. Car Alarms
    By Matt21385 in forum General Chat
    Last Post: 10th July 2006, 15:42
