Thread: intermittent check rear bulb warning
    Regular Member parttimer1's Avatar
    Dec 2010
    edinburgh
    Default intermittent check rear bulb warning
    Getting an intermittent check rear brake light warning on the siggy - pressing pedal clears it. Have removed and refit bulb, is this most likely an iffy brake pedal switch/sensor?
    Oh, and tiny hole in the rear glass lens (about 5mil across) - is this an MOT failure? Cheeky repair but if I fill with some coloured silicon (food colouring to same colour) would that pass? Concerned as Siggy rear light units seem to be hard to come by.
    Edit, re above question, would these rear lights really be legal for MOT? http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180677157251
    May 2006
    scotland
    Try replace the bulb? I had this once and it was the filament on the bulb that was making and breaking. I replaced the bulb with new and never a problem since (3 years now).
    luton
    had this too, replaced buld several times with halfords own brand, was getting really annoyed, someone on here suggested trying bosch bulbs, worked a treat, never happened after that, must be something about cheaper bulbs
    Regular Member Wolfie01's Avatar
    Nov 2010
    Wolverhampton
    I'm getting a similar problem the bulb warning light flashes as I am driving?
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    As wickedwillie said, try a new bulb; filiment making and breaking.
    Regular Member coooky's Avatar
    May 2011
    washington
    Quote Originally Posted by Wolfie01 View Post
    snap
    gonna change the bulbs thanx for this post and the answers
    Full Member Big Sig's Avatar
    Also try cleaning the contacts of the bulb and in the bulb holder.
    Dec 2010
    edinburgh
    Suggestions appreciated, new bulb this weekend.
    Any suggestions on the small hole in the lens? Seeing this 'lens' repair tape that will get through MOT apparently as it prevents light shining through and thats enough. Still fancy sticking some coloured silicon sealant in there though to make it look a bit better but anything to put off getting a new light unit.
    Engine : 1.9 CDTi
    Aslong as its showing the correct colour it will be fine
  1. Rear brake light bulb warning won't go off
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 21:39
  2. intermittent bulb fault light????
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2011, 22:31
  3. Intermittent Bulb Failure Warning - Nearside Front Indicator (Problem Solved!)
    By DanR in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 19:20
  4. Intermittent check engine light and limp mode
    By Loaf in forum Engine & Drivetrain
    Last Post: 16th April 2010, 10:43
  5. Rear left parking bulb warning
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 12:37
intermittent rear bulb in vectra
