Thread: Live wire when alarm on?
    Engine : 1.9 CDTi
    Default Live wire when alarm on?
    Is there a wire that's live when the alarm is set (Or deadlocked)?
    Engine : 1.9 CDTi
    Are there any?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Take a feed off the battery with a seperate earth and I would of thought that would be fine if thats what your after?
    Engine : 1.9 CDTi
    I want to power a microwave sensor so that when the car is alarmed it will turn on the microwave sensor to warn away if you get to close.
    Bordon, Hampshire
    maybe take a feed from the cone shaped button under the bonnet (facing upwards). Aparently its part of the alarm system to detect if the bonnet is opened...
    The live feed should be on once the alarm is activated and won't be switched off by the button on the dash that turns off the proximity sensors (I dont think anyway)
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    Quote Originally Posted by luke4487 View Post
    Thats where i am going to take a feed for a micro switch to enable my garage door to run off the car alarm....
    A Vauxhall techy suggested there too, should only be a live and earth there iirc
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Looking for a 'Live till locked' wire
    By Dave78 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 01:23
  3. Removed alarm speaker wire and now get error
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2009, 13:50
  4. rear live wire
    By biggest in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2008, 23:42
  5. Wire Free Home Alarm
    By Orka The Porka in forum General items for sale
    Last Post: 11th February 2007, 16:33
vauxhall alarm live wire
