Thread: USB socket
    Regular Member rockonoli1's Avatar
    Telford
    Default USB socket
    Has anyone fitted a USB socket in there car ? I want to fit one just purely for charging my iPhone but don't want to use the 12v socket
    Full Member
    South West
    Sort of....
    What i did was buy a 12v ciggy plug with a USB charger built into it. Snipped off the 12v ciggy end, and soldered it to the back of the 12v socket in the car. Ran the USB charger inside the center tunnel into the arm rest compartment, then the iPhone charger cable again through the tunnel and poked it up through a hole made in the center drinks holder.
    A neat tidy installation, and with the drinks holder closed, you would never know it was there. HTH
    Rgds
    Aidi
    Telford
    Cheers mate where did you get the lead from
    Full Member
    South West
    I think it was Halfords... !
    Telford
    Any photos Aidi?
    Regular Member Zark's Avatar
    Herts
    I've plugged a usb into the cigarette lighter for charging, and when listening to music or podcasts stored on phone, I get an interference buzz and whistling through the stereo.
    Would splicing a lead into the feed negate this?
    Happens with phone and mp3 player through 3.5mm aux to stereo...
    Full Member
    South West
    Quote Originally Posted by rockonoli1 View Post
    Any photos Aidi?
    Ill try and get some tomorrow and post them up for you
    Telford
    I want to put a USB port by my light switch (on the right of the dash) so that the iPhone lead can be tucked/hidden behind the dash and just have the charging end by my phone holder how would you get the voltage to drop from 12volts to the required 4.75 - 5.25 volts ? Any electrically gurus out there that can help?
    11 Post(s)
    Buy a ciggy lighter USB adapter, and attach some flying leads to the end that usually plugs into the ciggy socket and then attach the leads to a +ve and -ve connection in the car, making sure that you have a fuse in line to protect things.
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    I bought one of those belkin flush adapters. I had to modify it a little to fit flush (it's a touch too long) but once it's in and the spring loaded flap is in place, you wouldn't know it's there.
  1. socket set
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2012, 01:45
  2. USB socket ?
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2012, 16:36
  3. 12v aux socket
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2010, 20:58
  4. socket
    By Toyotacelicagt4 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2009, 19:38
  5. USB Socket/Aux In
    By armstma1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2007, 21:18
