Thread: Air con re-gassed but not as cold
    May 2011
    Nottingham
    Default Air con re-gassed but not as cold
    Had a hissing sound when i turned the air con on and it wasnt cold. Turned out the gas had run out, got it regassed and it was fine...until the other night. The hiss has come back when i turn it on, and it doesnt feel as cold now as it was just after the re-gas. Any body had a similar problem?.
    Mar 2007
    wrexham
    Vehicle : Vectra c
    Trim : SRI Estate
    Engine : 1.8 VVTI
    Year : 06
    Sounds like you got a leak (no pun intended). Did you have u/v dye added so you can see if it's leaking or not ?
    I fitted new condensor myself (about £105 from these)
    http://www.autoairconparts.co.uk/ (it was a valeo one ) 2 small washers cost about £30 from dealer.
    There are good instructions on here somewhere on how to remove the front bumper.
    Condensor is easy to change, just a couple of 13mm nuts I seem to recall ( maybe a 10 or 11mm as well ).
    May 2011
    Nottingham
    No, didnt check for that, will do asap.
    Thanks for the link and tips, heard how much these things could cost if i went to a dealer!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    an arm and a leg bud, dealers charge well over a couple of hundred quid just for the condensor!! and thats without fitting it and regassing it!!!
    May 2011
    Nottingham
    Damn it...no leaks, taking to a friend of a friend to have a look...hope nothing is broken.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. It's Getting Cold
    By slipperysam1984 in forum General Chat
    Last Post: 2nd November 2009, 13:34
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
