Results 1 to 10 of 11
Thread: 1.9cdti 150 16v engine glow plug size...
    May 2011
    Aberdeenshire
    Default 1.9cdti 150 16v engine glow plug size...
    Does anyone know off hand what size socket to use for the glow plugs on a 1.9cdti 150 16v engine? 9mm or 10mm?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    ten id say mate..........
    Regular Member sebadee's Avatar
    macclesfield
    You will need a 9mm deep socket
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Engine : 1.9 CDTi
    As above twice
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    When undoing them hold the socket up so it only covers the nut of the plug, dropping the socket down can cause it to be possible for it to pry against the head causing sideways pressure & snapping the plug off.
    May 2011
    Aberdeenshire
    Thanks for the answers - much appreciated.
    9mm tool and new plugs shall be purchased!
    Engine : 1.9 CDTi
    And probably cheaper from Vauxhall (Even cheaper if you join the club and use trade club )
    May 2011
    Aberdeenshire
    Update; job done cheers for the advice.
    Belfast
    Hi Guys,
    I was confused over this also! I'm looking at buying a new set, but looking on line I'm seeing 9mm and 10mm claiming to fit 1.9cdti 150??? Does it matter other than having a 9 & 10 mm socket?
    Also are any glow plugs better than others or is it best to stick with Vauxhalls plugs??
  1. 1.9cdti 120 glow plug replacement.
    By john1 in forum Engine & Drivetrain
    Last Post: 14th November 2011, 23:27
  2. What size is the Glow plug Socket?
    By GrizzaVision in forum Engine & Drivetrain
    Last Post: 20th April 2010, 20:54
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. what size glow plug socket
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 09:33
size socket for vectra 1.9 glow plugs
