Thread: Fumes inside car
    Feb 2011
    ashford kent
    Default Fumes inside car
    Hi all
    Signum 1.9 diesel 54plate
    when the fans on and the cars stationary fill up with fumes
    when i check under hood cant be sure if its coming from the breather rubber pipe if thats what it is ( T shaped pipe ) when you lean over the engine below the fuel filter can feal bottom clip but cant see if pipe is split .
    If its not this is their any other place it can escape down their
    On a Sabbatical mickeystitch's Avatar
    Mar 2007
    peacehaven
    Default flexi pipe
    flexi pipe on exhaust, when my turbo blew the other week I could not believe how much smoke was coming out of sides of it as well as back of car, mine is the same when standing still and has just come out of vaux stealer does not even sound split but i saw it myself so I know it must be
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    also take your engine cover off and make sure none of the injectors are chuffing(exhaust gases leaking from the cylinder) if they are you should see a load of black ****e around them that is like a hard tar sort of substance
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If its the 150ps check the swirls on the inlet manifold, exhaust gasses escape & are sucked into the heater system when stood or moving slow.
  1. fumes inside car
    By neil52 in forum Engine & Drivetrain
    Last Post: 6th April 2013, 08:59
  2. 1.9cdti Diesel fumes inside the cabin
    By kingarthas in forum Engine & Drivetrain
    Last Post: 23rd March 2013, 13:26
  3. DPF/CAT - Strong Fumes Smell inside cabing - CDTI 150
    By Vaux-Man-G in forum Diesel Engine related
    Last Post: 1st April 2012, 17:47
  4. Fumes
    By stevie16v in forum Engine & Drivetrain
    Last Post: 19th September 2011, 21:08
  5. Fumes In The Cab - Help!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2008, 19:27
vectra flexi pipe fumes in car
vectra c fumes inside car
fumes inside car
