Results 1 to 2 of 2
Thread: Z19DTH 150 engine problem;/
    Jun 2011
    edinburgh
    Default Z19DTH 150 engine problem;/
    Hello im owner of saab 9-3 estate late 2007 im looking for advice here because have the same engine.
    Problems start with code P2279 engin on poor perfonmance and finally wont start.
    -egr and solenoid clean
    -Throttle was clean
    After this engine start but still less power so go to garage and guy was done forced clean for dpf 0%
    i bought fiat gasket for egr
    After 3 days on bypass i get spanner and limp mode so connect opcom and get
    P242F-75 so delete this, car back to normal ,back to motorway to check if happen again and it is another 3 times also get one time code P242F-58.
    Back home and check in opcom dpf it was about 35% and last regen. about 530 km ago.
    Read from opcom for egr is:
    Contracted position EGR (Exhaust Gas Recirculation), 100%
    Pulse Ratio EGR (exhaust gas recirculation), 4%
    i do not know if this is right value..
    Do anybody know what it is?
    Jun 2011
    edinburgh
    just back from motorway about 50 min journey every 5-7 minutes P242F-75 go on i was drive on 4 gear over 3000 rpm for 25 min and on 6 gear at 2000 rpm and fault still going on every 5 minutes, opcom show dpf on 63 %
  1. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  2. problem with z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 27th April 2011, 19:20
  3. anyone got an exploded diagram of the z19dth engine ?
    By roswell in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 13:24
  4. z19dth TURBO problem ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 15th November 2007, 15:29
  5. z19dth new engine ecu
    By benny in forum Parts for sale
    Last Post: 6th April 2006, 21:40
p242f vectra c
