Results 1 to 10 of 23
Thread: Need Help Urgently Please
    Jun 2011
    Basingstoke
    Exclamation Need Help Urgently Please
    Im trying to do a de-cat mod and im stuck, my car is in bits at the moment and i could do with some advice.
    I read on here that once the front part of the exhaust is dropped there will be a mesh inside that needs knocking out but when i took it off to look its totally hollow but at the end it fits too on the engine side actually has the mesh ??
    Can i just knock this all out with a hammer and chisel as best as possible then simply fit the exhaust back on ?
    Sounds to easy to me.
    I have attached pictures to try and explain easier what im having difficulty in writing lol.
    Top pic is the exhaust leading down to what i think is the cat.
    The middle pic is the mesh at the engine side ( the side i need to smash up i believe ?? )
    Bottom pic is them both seperated
    Jun 2011
    Basingstoke
    vauxhall vectra 1.9cdti 120bhp 07 plate
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The part with the mesh in is the Pre Cat. Ideally you need to remove this to knock the mesh out unless anyone knows it can be done while still on the car. I would be worried that the turbo would get damaged if you did it while still on the car
    Jun 2011
    Basingstoke
    is this definitley the right piece to knock out though ?
    I cant see how you would ever be able to remove it to get to it ?
    Anyone know how its removed or can i just tap it with a hammer and chisel all the way around to try and get it out ?
    Jun 2011
    Basingstoke
    sorry didnt make it clear that im actually trying to remove the pre-cat not actually de-cat the car in full.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well you need to take the rad pack out and the heat shield then you will see the spring clip and bolt holding the top part of the precat. On refitting you would need new gaskets from Vauxhall to ensure you have no leaks. You might be able to remove the heat shield without taking the rad pack out but not sure
    Jun 2011
    Basingstoke
    Can it not be done whilst its fitted to car ? im not sure if vibrations will damage the turbo ?
    Regular Member Jezzy's Avatar
    S.E
    You seem really desperate to dirty the environment even more than necessary...why?
    Jun 2011
    Basingstoke
    Im trying to create more airflow and this restricts it a fair bit, the cat is still in place so nothing is made worse as far as i know
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by jammin31 View Post
    The mesh you can see is the cat! The mesh is what removes or helps remove the particles in the exhaust gas.
    I took the pre-cat out altogether and replaced it with a scorpion pre-cat pipe
  1. Help needing urgently!!!
    By Stevie_VXR in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 16:15
  2. Help Urgently Required... I've F*cked up!!!
    By BigMan in forum General Chat
    Last Post: 5th September 2007, 16:51
  3. needed urgently
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 12:42
