Results 1 to 2 of 2
Thread: 2.2DTI engine cuts out
    Jun 2011
    nottingham
    confused 2.2DTI engine cuts out
    Hi
    My 2.2 DTI Vectra keeps cutting out at speed, starts again but is dangerous and often.
    Dealer can't find fault, suggested EGR, replaced that, no change. Man in pub suggested unplug airflow sensor which when faulty doesn't give a code?
    Unplugged Airflow sensor, car runs without breaking down but eml on all the time and runs in safe mode. Replaced Airflow meter, problem returns. Flummoxed.
    Any ideas? Need a reliable Vaux / Diesel garage in Notts or Derby or a self help fix
    West Sussex
    Quote Originally Posted by ruthstatham View Post
    Hi
    I've got the same engine and I had the same problem, I'd be doing 70 on the motorway and it would cut out, I'd turn the key and it would start again..so dangerous. I took it to a VX specialist and although they had a TECH2 they couldn't find the problem, when I took it to a main dealer they read the problem straight away. I honestly can't remember now exactly what it was but is was something to do with the inlet manifold. If you haven't done so take it to a main dealer for a diagnostic.
    As I've said on here before, I was told that the diagnostic equipment is only as good as the person reading it, and I certainly found that to be true
    Phil
  1. 2.2DTI engine cuts out except when airflow unplugged
    By ruthstatham in forum Engine & Drivetrain
    Last Post: 27th June 2011, 22:19
  2. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  3. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  4. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  5. 2.2DTI - Revs drop and engine cuts out
    By altheman2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2008, 20:55
