Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: What Temp Does Your Car Run At?
    Barrow In Furness, Cumbria
    Default What Temp Does Your Car Run At?
    As above.
    Just curious as mine sits just over 1/2 way at around 91 / 92*c.
    2008, 1.8 VVT SRi.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    3.2 GSi (manual) typically holds to about 85 - Fans kick in if it points over straight up (90).
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Chris SRi View Post
    As above.
    2008, 1.8 VVT SRi.
    Seems too high to me - it's at about 92 that the fans should kick in and bring the temperature down to about 80-85.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    mine runs at between 80/85
    3.2 v6 Signum and loving it
    Is that on idle?
    Is that on idle after a long run at high speed? (the temperature gauge rising)
    What settings do you use for the internal heating system?
    You may find it is lower if you run with the air conditioning on, and even lower with fan settings higher, and with higher settings heat
    OXFORD
    My 1.8VVT runs straight up at 90 after about 3 miles and stays there.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    At this time of year i'm sitting at 90 all the time, sit in traffic hits 92, fan kicks in and drops to about 88 then back to 90.
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    OP,s car is spot on for a vvt, not that its running at the temp the gauge says, pull up the workshop menu on the center display and see whats really going on!
    Regular Member Exclusive BV's Avatar
    West Midlands
    i had my thermostat replaced last year and i am given to understand from numerous threads that quite a lot of the 1.8 vvt's on this forum (including mine) sit at 92 or thereabouts
    Sep 2009
    Glasgow
    cdti 150 new stat 2 months ago 85-90 degrees
  1. temp
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 19th January 2013, 19:44
  2. What's your temp at?
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 22:14
  3. What temp should air con be ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:49
  4. DTI temp
    Last Post: 23rd September 2010, 22:53
  5. outside air temp
    By leeashford in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 19:34
opel z20net temperature gauge between 80 and 85 www.vectra-c.com
at what temperature should fan cut in on 2008 1.8 vvt vectra c
vectra c z20net engine gauge temperature www.vectra-c.com
