Results 1 to 10 of 18
Thread: Compresing rear caliper piston.
    Oct 2006
    UK
    Unhappy Compresing rear caliper piston.
    Can anyone tell me how to compress the piston on the rear calipers on a vectra C? I can't shift the thing at all not even to get the old shoes back in.
    Thanks in advance.
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Dont force them rule one!!! What you need is a caliper wind back tool. this fits between the caliper and caliper body and you actually 'wind' the caliper back in. This tool should be available from Halfrauds.
    Here, there and every where!
    What Dean said!!!!! Don't force it back in. The piston needs to be wound in. I made a tool from some flat bar
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    yeah u need the windback tool, but i found it difficult to find the tool specifically for vauxhalls on its own, i had to buy a 8 piece set.
    Regular Member Harry's Avatar
    Uxbridge, London
    aren't you supposed to take the cap off the brake fluid reservoir before pushing the piston back?!?
    or is that not necessary anymore?
    Long nose pliers should do the trick matey.
    Uxbridge, London
    and a grip like a vice!
    Quote Originally Posted by Harry
    I didn't need a grip like a vice matey; I had a Drinky
    Uxbridge, London
    that's exactly my point!!!
    Oct 2006
    UK
    I managed to wind them in using some grips. But with the new pads fitted I get no resistance from the pedal unless I pump it laike crazy. Any ideas?
    Also, how are you supposed to wind in the piston whilst its still on the disk and stuck because the discs are worn a bit?
  1. caliper piston rubber gator
    By N14 in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2012, 21:29
  2. caliper piston size
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 22:39
  3. Brake Caliper piston broken
    By elite itchy in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2011, 09:51
  4. rear caliper/piston problems
    By rec in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2010, 21:37
  5. HELP!!! caliper piston seal...
    By danBoy in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 12:04
