Thread: wiring from bumper into boot???? HOW
    Regular Member degsy1234's Avatar
    Jan 2010
    Here
    Default wiring from bumper into boot???? HOW
    Hi All
    going to fit a meta sr2 reverse sensor. How do i run the wiring from the number plate sensors into the boot/ fuse area?
    Thanks in advance
    Regular Member benny's Avatar
    Feb 2006
    dudley
    use the number plate light loom run where it goes into the body ..
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by benny View Post
    thats exactly what I did with mine.
    Jan 2010
    Here
    thanks. i'll have a look at it tonight when i get chance. Hopefully its easy
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    I also used this, there is a grommet which just pops out. I cut a segment out of grommet with craft knife to make room for reverse sensor wires. I then pulled wires tight and taped excess together then coiled it in spare wheel compartment. You can feed it behind carpet into the light cluster bay, so no wires showing. This was for the four sensors you drill bumper for; sounds like yours i s different, but method will still be same i reckon
  1. Is there wiring in the boot of a signum for a power outlet?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2012, 19:40
  2. Wiring in drivers side boot compartment?
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2011, 12:59
  3. debadged boot and new bumper...
    By w33lerd33ler in forum Styling
    Last Post: 18th September 2009, 13:26
  4. Wiring amp to boot
    By thegoldenbullet in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 22:10
  5. Boot Area Wiring
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2007, 18:17
