Results 1 to 10 of 11
Thread: Radiator Leak Advise Please
    Lincs
    Default Radiator Leak Advise Please
    I am losing water from the bottom of the radiator at a rate of about a pint every 200 miles. Is there something safe i can put in the water for a temporary fix? Is radweld or something like that ok in our cars?
    Paul.
    Jul 2009
    The Rift, Cardiff
    Just keep topping it up until you can get a new radiator fitted. I had the same problem and wouldn't use radweld or similar for fear of blocking the matrix or a fine coolant line.
    leeds
    Vehicle : vectra
    Trim : sri
    Engine : 3.0 cdti
    Mileage : 55000
    rad seal aint a permanent solution so prob best to just keep topping it uptill u can get it done
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Iprefer to use a product called Bars Leaks. I used it on a previous car and ran it for almost 2 years with itwith absolutely no problems at all.
    3.2 v6 Signum and loving it
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    It's prob not something you want to put in your car but when I was in afghan I repaired a radiator with egg whites
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by CritchvxD View Post
    Done that as well ran it for months before I could afford a new radiator. It was damaged in an accident. It had at least 4 broken vanes which were bent and crimped back to seal them. I had no choice was miles from nowhere and no mobile phone to phone for help.
    Lincs
    Thanks chaps, sorry for late response, i've had no BT line for a while. Just got fixed.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Dont use any of it. I had your problem, and every shop i went to,,,, every garage i asked shot me down and sed most sealant products are for older cars, and will cause alot more problems in the future with matrix ect.. just keep topping up the water untill u can afford a new rad. I payed 100 fitted for a valeo one in my 1.8 petrol, My mates garage like so rekon you will be looking at about 150. Hope that helps
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by pauldellboy View Post
    You mean you had the BT line fixed or the car?
    Regular Member coooky's Avatar
    May 2011
    washington
    Quote Originally Posted by Johnsdutton View Post
    Where did you get the eggs a birds nest
  1. advise needed on radiator
    By dcm23251981 in forum Engine & Drivetrain
    Last Post: 4th March 2012, 19:18
  2. Radiator leak
    By dansoap in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 21:22
  3. Radiator Leak
    By si_hoss in forum Engine & Drivetrain
    Last Post: 10th June 2010, 13:13
  4. 1.8 sxi radiator leak
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 12:51
  5. radiator leak
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 07:17
