Thread: 1.9 cdti 120 z19dt engine
    Regular Member roshaan's Avatar
    west midlands
    Default 1.9 cdti 120 z19dt engine
    the cambelt went it bent 7 valves had it done new cambelt after that it blew original turbo engine keeps killing turbos on 3rd turbo cars parked up any ideas getting no luck should i change engine?????
    Regular Member benny's Avatar
    Feb 2006
    dudley
    has the oil return pipe been bent / crimped over when the head was removed very common fault now there getting older and the heads have been off ......also have you replaced the oil feed banjo bolt every time the turbo has been replaced ....have you been useing new units or recon ? .... what other damage was done when the cambelt went .? ...they normally damage the cam / brake vac pump ......
    lincolnshire
    stick another engine in it and do the belt and waterpump before you do !
    west midlands
    Cool
    Quote Originally Posted by benny View Post
    what I was told is the cam belt snapped, bent seven of the eight valves, head was skimmed and seven valves replaced, after that it blew original turbo. Had two recon turbo's, they lasted a day. Since then car was parked up...garage don't appear to have a clue! I noticed the temperature guage was reading half way, and then no reading , but heating appeared to be working okay. Was told that turbo's had blown, due to no oil in bearings. Not sure whether banjo bolt replaced... I reckon cowboy garage, as they do not appear to know much about turbo diesels! P.S just before the turbo lost power, I heard hissing noise from the head area of the engine, like a dump valve hiss then it lost power. So at this moment I am on the look out for an engine.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
z19dt timing belt snapped
z19dt cambelt snapped 120
