Results 1 to 10 of 26
Thread: Parking sensors fitted
    Central Scotland
    Default Parking sensors fitted
    Hi all,
    bought myself a parking sensor kit from Steel Mate. Sprayed the sensors to match the car and fitted them today. I did not remove the bumper because I decided to mount the sensors in a different position from the factory one.
    To power the sensors I spliced the supply to the reversing light from the wiring at the connector to the lighting module. This has not caused any problems with the lamp failure warning system. I mounted the display for the system above the rear view mirror running the cable around the rubber strip at the roof covering and down into the boot space. I had to remove the alarm sensor at the interior light to get the wiring for the display in place.
    The system gives a voice warning telling the distance from the object, a bleep warning and a display of where the object is according to the sensors. Quite smart actually. Well impressed with it. I can well recommend the Steel Mate sensors. They might cost a little bit more than some sensors but the are good quality and also have a three year warranty. They also provide help over the phone. All in all a very good service.
    Some piccies attached for you to have a look at.
    Ian
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    They look factory, and the display is a bonus
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Looks really good......
    OK, stupid question time - how did you put the sensors on without removing the bumper? Drill through and feed the wires?
    Thanks - look forward to your reply
    Central Scotland
    Just drilled through and fed in the wires. Connected the cables to the sensors first to make it a bit easier. The only bit that requires real care is for the sensors above the number plate. They have to be drilled accurately to fit in between the bolts for mounting the bumper and the plate lights. Measure several times and drill.
    Ian
    Regular Member Harry's Avatar
    Uxbridge, London
    looks like a very neat installation! nice work!
    how much did the kit cost you?
    any chance of a pic of the display working?
    cheers
    Jul 2006
    On the road
    Cheers - That's what I like about this forum......... all the other people!!
    Central Scotland
    Picture of the display working. I just taken it so its not very clear, a bit too dark for the camera but it should be enough to get the idea.
    The kit cost me £125.
    Uxbridge, London
    WOW!!! You're not going to miss that display are you!??!
    Very nice! Good quality piece of kit
    Jul 2006
    On the road
    Got a website URL??
    Central Scotland
    http://www.steelmate.co.uk
    The kit I fitted is the PTS400V
    Ian
  1. Parking Sensors fitted
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2013, 12:37
  2. fitted parking sensors
    By norrisCDTISRI in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 13:59
  3. Fitted Parking Sensors
    By MrDerv in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 17:46
  4. Parking sensors fitted
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 18:38
  5. Parking sensors fitted
    By jonesy_ni in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2008, 08:13
