Results 1 to 10 of 18
Thread: Z20net Turbo td04
    Apr 2011
    Berkshire
    Default Z20net Turbo td04
    Am I right in saying that a prefacelift z20net won't run properly if you fit a td04 from the facelift z20net unless it has been mapped for it?
    Could I just have the map of the facelift models put on the car?
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    I know they won't work on a mapped car without software or remap tweak.
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The early 2.0T's have a Garret low pressure turbo fitted which runs about 10.5psi in standard form and can be mapped up to about 16psi (mine's running 15.9). For higher pressures than that you need to look at either the TD04 from the facelift as you mention or a hybrid. Either needs a re-map to use it properly though.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    the car will run but it will needs a new map of sorts to make it function properly..
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Mine is a 55 plate facelift which turbo do I have
    morecambe
    33 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    td04 mate
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    So is that the mistibushi unit the high pressure one
    morecambe
    33 Post(s)
    Vehicle : vectra
    Trim : vxr
    i think the pre face lifts are a mitsi turbo mate the facelift are td04
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Right so am I right in thinking that I have the green injectors too
    Regular Member Jezzy's Avatar
    S.E
    The prefacelift will have the Garrett.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. B207R FMIC TD04 TURBO etc etc
    By total_vxl in forum Tuning
    Last Post: 25th February 2011, 11:21
  3. Fmic td04 turbo crankcase breather etc
    Last Post: 24th February 2011, 21:57
z20net turbo upgrade
z20net turbo
z20net vxr turbo
z20net Garrett or td04
