Thread: Parking pilot switch
    middlesbrough
    Default Parking pilot switch
    just wounderd if any1 else could shed some light about moding a standard park assist switch so i can turn it on or off. as I've bought an after Market sensor kit of eBay. I've already put the switch in just to see what happens orange light doesn't come on when you press the switch. but illuminates when you put the lights on.
    Admin plasma's Avatar
    On the Forum
    312 Post(s)
    Engine : 150
    Mileage : 74000
    you need a latching type of relay and wire that in to switch the parking kit. the switch just sends a pulse and is not latching
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    middlesbrough
    Sorry to sound dopey but what's a latching relay? also where can I get one, is there a diagram to show how it's done thanks
    Dunstable
    There are 2 resistors inside the switch, 1 for the led and the other is connected to the switch contact, if you remove this resistor it turns it into a "normal" button, but you will need a latching relay board such as this so that when you push the button the circuit stays on and when you push it again it turns it off. You can then wire any accessory you want to it.
    middlesbrough
    Can you tell me what the four wires are for on the rear of the switch are for thanks
  1. Parking Pilot Problems
    By Griff72 in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2012, 10:14
  2. For Sale: oe rear parking pilot kit
    By andy.l in forum Parts for sale
    Last Post: 8th January 2012, 01:05
  3. Parking Pilot Problems
    Last Post: 5th February 2011, 22:13
  4. Parking Pilot fault
    By Wing in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2008, 00:52
  5. Parking Pilot Switch
    By pmw123 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2008, 21:47
vauxhall parking pilot button www.vectra-c.com
insignia parking pilot switch
