Recently (twice in a week over 500 miles) the car's clutch pedal has gone almost right to the floor with minimal pressure required, only to return to normal operation after pumping the pedal around 5-6 times.
Both times this has happened it has been after going around 3/4 way round a roundabout - not sure if this is a factor.
Has anyone else had a similar issue? I'm ruling out the clutch pedal spring initially as the clutch operation returns to normal shortly after the problem has occurred.
Chris
