Results 1 to 3 of 3
Thread: HEEELLLPPP!!! Smoking Brembos...
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Exclamation HEEELLLPPP!!! Smoking Brembos...
    I am not pleased...
    Fitted new Mintex discs and Brembo pads to the Siggy around 600 miles ago. Had a pulsing steering wheel at high speed braking and after checking on the brake tester my left disc was ever so slightly off running true.
    I put this down to my stupid idea of putting ceramic grease between the disc and hub to stop it sticking/rusting (We will ignore this point)...
    Took the wheel off and gave it some spins to smooth off the ceramic paste and see if it helped (as haven't the time today to remove the calipers etc etc) and took it for a spin...
    We are talking under 10 miles of racing upto 80-100mph and braking from between medium to harsh braking (but not ABS harshness) down to 30-40 and repeating... (and there is slightly less vibration so they are getting cleaned when I have time).
    I got home and had the car on idle whilst I checked wheel nut torques and the brakes were literally SMOKING... there is some blueing to the discs also
    Surely this isn't right... My friend did say he had something similiar on his Evo so he changed back to Mintex and a few forums say this can be normal for newish pads? This is the first real thrashing they have had after bedding in but I have never had this before so bad?
    The blueing is the part that worries me the most... as its an MOT failure and mine is due in 3 weeks
    Anyone who has had the same problems or fitted the Brembo aftermarket pads please reassure me or let me know if there is something very wrong. They aren't binding as like I said I was spinning the disc freely between the pads earlier
    Oct 2007
    Shropshire
    I do not know about the blueing but the temperatures can easily reach over a 1000 degrees with hard braking from the speeds you describe and you should have drove for a few miles afterwards to let them cool.
    The only thing I suggest is get them really hot again, but then drive round for about 20mins without really using them to let the air rushing past cool them rather than then stopping and letting the heat just stay there... I do not know if it will work but only costs you time and a bit of feul to try.
    If this does not help at least it is a free bump!!!
    Regular Member Craig1985's Avatar
    harwich essex
    It can take unto 1000 miles for brakes to bed in before any heavy breaking
  1. Thats it, i've given up smoking
    By Ademusic in forum The 'Off Topic' room
    Last Post: 22nd May 2010, 12:47
  2. smoking
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2010, 19:21
  3. smoking
    By dominic32 in forum Engine & Drivetrain
    Last Post: 24th June 2009, 23:20
  4. Smoking
    By andymagee1982 in forum The 'Off Topic' room
    Last Post: 7th March 2009, 09:29
  5. Smoking
    By James Stewart in forum The 'Off Topic' room
    Last Post: 5th March 2009, 21:26
