Thread: Loss of power diagnosis Vectra 1.9 CDti
    May 2011
    Dishforth, North Yorkshire
    Default Loss of power diagnosis Vectra 1.9 CDti
    Just had the codes read by my local independent Vauxhall garage due to serious lack of power below 2500 revs (feels like I'm driving a truck) don't know the exact codes that came back as I forgot to write them down but as I remember the codes that were revealed were I think:
    • Swirl Actuator Supply Voltage Range/Performance
    • Injector Circuit Open / Shorted - Cylinder #1
    • Injector Circuit Open / Shorted - Cylinder #3
    .....and something to do with the EGR but this has been newly replaced so hopefully not an issue.
    Does this sound like an electrical issue with the injectors as it hasn't had the mod done yet.
    Matt
    May 2011
    Please Help
    Full Member Big Sig's Avatar
    Looks to me - and I may be wrong - that you need a new inlet manifold.
    May 2011
    Just had it replaced mate
    May 2011
    The power was there prior to having the Inlet Manifold, Swirl Actuator, Water Pump, Timing Belt and Throttle Body replaced. But now....nothing.
    Did they change the actuator? Have you looked to see if it operates correctly?
    May 2011
    I hope so, I paid for it to be replaced :s How do I know if its working correctly?
    Look at it and get someone to turn the ignition on. IIRC it will do a self test. Check for full range of motion.
    If you have had it all replaced recently, are these present or stored codes?
    lincolnshire
    i'd go for EGR valve ! even though you have codes
    May 2011
    Ok, I'll get that checked to see if everything is working as it should be. The EGR valve has been replaced only 1 month a go.
  1. vectra 3.0 sri cdti: 75 % power loss. No inection
    By mtqn in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:47
  2. Power Loss Vectra V6 3.0 CDTI
    By renwich in forum Y & Z30DT Specific
    Last Post: 7th September 2011, 22:52
  3. Vectra c 3.0 cdti ( loss of power )
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 20:58
  4. Help with Vectra CDTI SRI 150 - Car loss of power
    By dan912 in forum Troubleshooting
    Last Post: 27th May 2011, 08:59
  5. Vectra CDTi 150 - Loss of Power
    By Chappers. in forum Engine & Drivetrain
    Last Post: 4th January 2011, 23:37
vectra c cdti loss of turbo power
