Thread: Simple, Easy or Cheap mods to do 1.9 CDTi
    Regular Member Coupe2T's Avatar
    May 2011
    Hampshire
    Default Simple, Easy or Cheap mods to do 1.9 CDTi
    As title really, Looking at what the first mods should be? I'm planning on doing the airbox mod tomorrows, which as far as I know is simply removing the pipe, then I will pick up a performance filter at some point, but what else is worth doing in terms of pretty quick, simple and not to costly mods?
    I had an Astra Coupe Turbo prior to this and the first one mentioned was always to replace the precat with a precat decat pipe. Is the exhaust similarly restrictive on the diesels?
    I'm surprised there isn't a sticky for first power tuning mods to do like there is for the first simple styling mods to do. Maybe someone could throw something together who knows what they are talking about???
    Sorry, should probably also point out it's a 150!!!
    lincolnshire
    blank EGR , clean boost sensor , tuning box or remap , swap vac pipes for silicon type
    May 2011
    Hampshire
    Quote Originally Posted by bembo449 View Post
    I assume most of them are easy DIY jobbies. Does anywhere do kits for replacing the vac pipes etc so I can see what is needed? Is there a How2 on here for these things?
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    Not really any help but i had a coupe tubby, god i loved it, done what you did with all millteck stuff and a courtenay stg1 remap.... pleasant times.
    May 2011
    Hampshire
    Quote Originally Posted by disco dan View Post
    Yeah, did love the Astra and sad to see her go, but soon to be a family man so have to do what's best! I had just fitted and FMIC and everything, so a re-map would of seen her past 250bhp I reckon, only 35k on the clock, pulled like a tank for a petrol car!
    Still, onwards and upwards! If I can see 200bhp out of the Derv then i'm sure that will be pretty damn rapid too! lol
    Liverpool
    K&N panel filter with airbox mod(s), vac hoses to single piece silcone pipes, EGR blanking, tuning box
    they are the cheapest i can think of lol
    i have a 2nd intake into my airbox, few conversation have been had on wether or not it is a bad think as its breathing air from under bonnet, but i am going to build a customer cold air feed to it soon!
    Regular Member GrantAbs7's Avatar
    belfast
    Quote Originally Posted by paul_sri150 View Post
    Basically just what he said
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Sell it and buy 2.0t lol
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    LMAO!!!! yeah, Good one I needed a laugh
    You just need a tuning box in a 1.9CDTI and it will beat off a standard 2.0t, while using half as much fuel, costing less to insure and less to tax. You made the right move Coupe
    If you want to keep it as cheap as possible then just a tuning box will do the trick. Not much point in doing lots of other little bits, they will gain you very little.
    If you want to spend some money, I would go straight for a hybrid turbo and a remap or CRD-T tuning box. If you have the skills to fit the turbo yourself, you'll be looking at around £1000-1500 total for the turbo and map/box and it will transform the car.
    If your skills are upto it, reworking a turbo with a new compressor only (52mm would be as big as I went without reworking the turbine) would be very simple and only around £100 including balancing after reworking. I'm looking at £140 worth of parts plus and oil change for the new hybrid I am making, with a big turbine rework too.
    What is simple, easy or cheap depends on how handy you are with the spanners and what you concider cheap?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Coupe2T View Post
    Think my kit came from paulsri150 on here, made quite a difference.
    There are How to's for EGR valve and most of the others things mentioned, not for vac pipes as it's so easy.
    You might also want to look up Duncan's mod, listed as something like "a fix for the pre facelift headlights".
    It's applicable to Facelift as well. If you don't have HID's factory fitted, but do have the beam height adjuster on the right hand side of the dash, next to headlight switch. This raises the stupidly low dip beam height so that normal or HID bulbs shine where they're supposed to. All it takes is a flat surface to shine the beams on, and an allen key.
  1. Simple and cheap Mods
    By owen_999 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2013, 14:41
  2. cheap and easy mods
    By bobssignum in forum Comedy & Humour
    Last Post: 1st July 2010, 07:33
  3. Easy Cheap Mods
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 21:02
  4. Cheap, and easy mods
    By Keith Fusco in forum Styling
    Last Post: 21st December 2008, 20:56
vectra z19dt fast mods www.vectra-c.com
1.9 cdti easy mods
z19dt diy remap
vectra cdti simple mods
1.9cdti cheap mods
1.9cdti exhaust mod
simple z19dt modifications
