Thread: grinding noise coming from rear wheels
    May 2011
    sunderland
    Default grinding noise coming from rear wheels
    Hi everyone hope someone can help. Theres a grinding noise coming from the rear wheels when applying the brakes but the noise only starts as the car is coming to a halt. First thing is the pads are nearly new from vx and when jacked up the wheel moves freely any ideas
    Full Member spennny's Avatar
    Blantyre
    Is it always there mate or just when you initially use the car for the first 10-15 mins of brake use
    Have you checked there are no stones or anything between pads and discs ?
    Did you use copper grease on the piston when changing the pads ??
    May 2011
    sunderland
    Seems to be after about 15 mins of driving but its only as the car is stopping
    May 2011
    sunderland
    Also when u apply the brake it as tho the pads need changing but the discs and pads are practically new then when u take your foot off the brake the pads are grinding on the discs and the fater u go then quicker the noise its as tho the pads are not realsing from the disc. Need help please guys
  1. Noise coming from the rear
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:16
  2. hello any1 help with noise coming from rear wheels
    By yulieb in forum Suspension, Wheels & Brakes
    Last Post: 13th July 2011, 22:09
  3. Grinding noise from the rear breaks
    By freddy in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 18:07
  4. signum..grinding noise from rear
    By uaintsinme..right in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2009, 21:47
  5. Strange grinding noise coming from rear wheel
    By sproket in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 22:04
