Thread: Error P0425 Exhaust Gas Temperature Sensor High Voltage
    London
    Smile Error P0425 Exhaust Gas Temperature Sensor High Voltage
    I have been away from the vauxhall scene for a couple of years but recently bought myself a vectra 1.9 cdti auto 2005 model. Car has 112000 miles on it and drives spot on,
    I'm hoping someone can help with my spanner light issue which was originally intermittent but now comes on every journey.
    I've had the codes read and its p0425 - exhaust gas temperature sensor high voltage bank one sensor one. I know this is the sensor on the pre-cat just below the turbo but before I go replace it was wondering if anyone has come across a similar problem and turned out to be something different e.g. dodgy connection or perhaps something else causing the error besides the sensor itself. From past experience i've shelled out loads on parts "because the computer says so" and quite often its turned out to be a simple fix and not a faulty part.
    Is there any way to tst the sensor before replacing??
    Any tips appreciated
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    come accross this before at work before and its been the sensor its self faulty
    London
    Quote Originally Posted by paul wingnut View Post
    cheers for the quick reply. Do you have any tips for removing it.. first glance looks like its a bit tight to get at?
    Apr 2012
    anglesey
    I'm sorry I know this is a very old feed but had the same code. Did replacing the sensor work and is it the one below the turbo or the one on diesel particulate filter. thanks
  1. Instrument Dimming Bulb Output Circuit Open or High Voltage
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2016, 20:24
  2. Replies: 5
    Last Post: 3rd January 2013, 21:56
  3. High temperature and a bit of smoke!
    By Hopewell in forum Engine & Drivetrain
    Last Post: 28th July 2011, 18:34
  4. Replies: 9
    Last Post: 15th October 2010, 17:57
  5. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
p0425 vauxhall
p0425
Vauxhall P0425
p0425 opel
exhaust gas temp sensor insignia cdti
Opel DTC P0425-05exhaust gas temperature sensor 1 bank 1 high voltage on a zafira 1.9 cdti 2008vauxhall insignia cdti exhaust gas temp sensorvauxhall exhaust gas temperature sensorexhaust gas temperature sensor zafirahttps:www.vectra-c.comforumshowthread.php140174-Error-P0425-Exhaust-Gas-Temperature-Sensor-High-Voltagezafira b egt sensoropel astra p0425zafira exhaust temperature sensorastra h p0425 fault codezafira b exhaust gas temp sensorvectra c exhaust gas temperature sensor2008 vectra 1.9 cdti exhaust temp readingsP0425 Exhaust Gas Temperature Sensor Low mitsubishi fault code p0425exhaust gas temperature sensor vectrasaab p0425 exhaust gas temp sensorOpel P0425insignia exhaust temperature sensor Exhaust Gas Temperature Sensor 2 High Voltage.
