Results 1 to 10 of 19
Thread: Display safe question
    Regular Member kevcdti's Avatar
    North east
    Default Display safe question
    I've got a 2005 vectra sxi fitted with CD30 and standard clock screen,I've bought a paired CD30 with TID
    When I switch the radio or ignition on my display comes on,lets me do anything I want but 20 seconds later it shows up "Display safe" and stays like this until I turn it off and leave it for abit ?
    After a few minutes I turn it on and get the same again can do pretty much anything for the first 20 seconds then get the same "Display safe" message
    North east
    anyone ?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    did the units not come with a code?? cos it sounds like they are not paired
    North east
    Bought them off ebay as a paired screen and CD30
    Removed from a Vectra C 2006
    Perfect working order no code needed fit and play
    Just been out to the car again,radio switches on,I can scroll through menu,changes radio station etc but once 20 seconds is up I get "Display safe"
    Are you VXR Enough
    13 Post(s)
    then it sounds like they aint paired fella
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Did you also switch to the screen you bought? if yes.. they are not a "pair" but will need decoding and paired to your car..
    if you dint change the screen over too, then you will have to have the radio decoded and paired to your car.
    North east
    what will I need to do to sort it ?
    I'd rather not send them back I've already waited a week for them to turn up plus by the time I cover postage this could be put towards sorting them
    North east
    Kenp they were bought as a pair and both fitted at the same time
    Engine : 2.2 Direct
    Then they was not from the same car..
    You will have to have both decoded from a specialist.. and then have VX or other with the abilities to code them to your car..
    North east
    can vx decode them ?
    do I need any details from the donor car to sort this,I've emailed the seller but yet to get a reply
    Thanks for the advice chris and ken
  1. Display Safe??
    By vectra19 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2012, 20:26
  2. display safe
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 10th May 2012, 23:46
  3. getting around the display safe
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2011, 02:39
  4. display safe !!??
    By bravocorsa in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2008, 15:10
  5. Display Safe
    By noseer in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2007, 16:22
vectra c display safe
vauxhall vectra display safe
vectra display safe
vectra c radio display safe
display safe vectra c
display safe opel vectra c
opel signum display safe
display safe vauxhall vectra
2005 opel corsa display safe
opel omega display safevectra c display omegaledisplay safe vectra c 2005 how to get rid of display safe on vectra chow to remove display safe vauxhalldisplay safe vauxhall zafiraturn display safe off on vectra 2007vectra shows display safeopel corsa c display safe messagevectra cd30 display safedisplay safe opel vectra cd30how to set vectra display safedisplay safe vectra c how to get it off display safe on a vauxhall vectradisplay safe on vectra
