Hi guys, ever since ive had my car the CC has hardly worked. i have cleaned the stalk and switch, the brake switch functions well, and the clutch spring is fitted. my car doesnt have a clutch switch as this was removed by the prveious owner which i recently discovered and so the few times my CC did work the car would rev out when the clutch was depressed rather than cutting CC.
Now, having not modified anything, the CC just wont work anymore, so should i suspect the stalk and try a replacement?
Also, should the clutch switch wires, if i was to maintain bypassing a switch be connected or not to allow the CC to function whilst i sort my problem?
Cheers!
Thom
