Thread: v/c cdti 120 knockin sound
    New Member djdee's Avatar
    Mar 2011
    holyhead
    Default v/c cdti 120 knockin sound
    got the vectra cdti 120 on an 07 plate,wen its warm there is a knocking/metal noise comin from the cam side,i put a drop of oil in an its gone for now,any idea wat the hell it could be,just done cambelt but not w/pump...
    Regular Member Jackvectra18's Avatar
    Winchester
    Quote Originally Posted by djdee View Post
    Put oil in the engine or around the knocking noise?
    Mar 2011
    holyhead
    Wink Oil change
    How much do i put in from empty,its the 1.9 120bhp cdti,cheers for the help.
    4.3 litres when you change the oil and filter.
    Mar 2011
    holyhead
    Default oil change
    thanks 4 your help bud....do i need to replace the oil ring on filter change..an wats the pros to remove it???
    Use a six sided 13 mm socket to remove the sump plug as anything else will round off the corners of the hex, they seem to be very soft. You should get a new rubber seal with the new filter and you will need a 32mm or one and a quarter inch AF socket to remove the top of the filter housing.
    Mar 2011
    holyhead
    confused oil change
    cheers for the info,it is done,also there is wyning sound now coming from the engine pulley,but which one is it?there are a few of them on the fleet,an mine has just started to do it?only wen i'm slowing down in gear,it sounds like a dynamo,an i've just put a brand new alternator on,could it be the automatic pretentioner on the aux belt???????
  1. odd sound from cdti v6 vectra
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 22:49
  2. odd sound from cdti v6 vectra
    By v6 sri diesel in forum Vectra C / Signum Troubleshooting
    Last Post: 6th December 2010, 21:11
  3. What does a cdti sound like with a performance exhaust?
    By ONEMINUTESILENCE in forum Diesel Engine related
    Last Post: 26th October 2010, 21:01
