Results 1 to 10 of 15
Thread: CDTI 120 Intake flap
    Regular Member Jackvectra18's Avatar
    Winchester
    Default CDTI 120 Intake flap
    Hi there,
    Ive recently experienced the EML on, Had my fault codes checked today by a friend of mine and it comes back with "Intake flap actuator" Ive heard of the 150 intake/swirl flaps malfunctioning but obviously the 120 cdti does not suffer from this fault, Ive left the bit of paper in my toolbox at work but im pretty sure this is the code, will verify tomorrow if i remember it!
    The only thing i can think of is there is an intermittent internal fault in the throttle housing, as it only happens everynow and again. The car doesnt seem to loose any power at all (as much as a 120 has lol) when this happens, i just dont like looking at the light.
    If anyone has any info i will be very gratefull!
    Thanks in advance, Jack
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    If you have engine code z19DTJ you have a 16V engine with 120 hp and flap. Take a look at the engine and see what you have. If oil cap its at the other side of the register its a 16 v and actually a cdti 150, downtuned to 120 hp.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Winchester
    Im 100% sure its an 8 valve! I rebuilt the head on it lol
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    As said m8, if it was the 8V, then you would not have it at all, as the flaps are only present on the secondary port runners.
    The oil cap is a give away.
    Winchester
    Quote Originally Posted by Gazza4 View Post
    Yeah this is what makes me think that this fault code refers to the electronic throttle, as the 120 8v has no flaps.
    Well there is a long story for me rebuilding the head . . . For no aparent reason
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Jackvectra18 View Post
    Why did you not just check the throttle body then?
    A throttle body fault would normally say Throttle in it.
    Winchester
    Oh it was about 20k ago i rebuilt the top end
    Yeah there is that, but referring to an "intake flap" suggets towards the throttle surely?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I've had the throttle fault - common fault but really affects the earlier CDTI's 2004-05. On earlier ones the solder joints crack causing. Yours is slightly different inside, but have a look anyway. I took my throttle plate off as I was fed up with it shutting my engine down. I've soldered up the cracked solder joints though.
    Intake suggest - yes one. But if you have taken the head apart you would have came across the drive actuator it is seemingly moaning about.
    Winchester
    Ahh fair enough, cheers for the info, Did you notice any oil in your throttle? theres not an excessive amount, Mine just seems a bit damp.
  1. Intake Air Flap Actuator
    By rickylennan in forum General Motoring Chat
    Last Post: 23rd January 2012, 22:33
  2. Intake Air Flap Actuator
    By rickylennan in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2012, 21:32
  3. Swirl Flap operation checking on 1.9 cdti
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 18:15
  4. air intake cdti 150
    By chrisgettings in forum Diesel Engine related
    Last Post: 3rd February 2008, 02:49
  5. Intake flap broken?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 23rd November 2007, 12:33
