Results 1 to 3 of 3
Thread: Clean boost sensor?
    May 2008
    manchester
    Default Clean boost sensor?
    Hi Guys
    My car has been cured from the dreaded "misfire" / "flat spot"
    Garage replaced EGR and it still misfired, but I cleaned the Boost Sensor,which was absolutley caked solid in hard soot like deposits, and seen a massive improvement.
    My question is.... the part of the engine I removed the Boost Sensor from, what is it called? And if the boost sensor was solid with crap then is it possible this "part" where the boost valve is in, is also full of crap?
    If so would it be worth cleaning this out,and is it a do at home job?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    You talking about a DTI engine? I call that the throttle body (might be wrong but sure it's that lol), on my DTI I took it off and scrapped /cleaned it out as it was gunked up really badly. Only had the EML a few times before but never had it since and that's nearly a year ago (reminds me I better go over it all again!).
    May 2008
    manchester
    Quote Originally Posted by si_hoss View Post
    Yes its 1.9 cdti 120
  1. Boost sensor clean
    By Ruffus2 in forum Engine & Drivetrain
    Last Post: 14th August 2012, 18:22
  2. Boost sensor clean up problem.
    By carperjake in forum Engine & Drivetrain
    Last Post: 17th July 2012, 22:39
  3. Boost sensor clean!.
    By felixx in forum Engine & Drivetrain
    Last Post: 18th July 2010, 23:37
clean boost sensor vectra c
