Thread: Leaking shocker?
    Feb 2011
    Bradford
    Default Leaking shocker?
    i have awful rattling noise coming from my rear passenger wheel. It sound like when you shake an empty spray paint can, when the thing inside rattles. I was told i have a leaking shocker the other week and was wondering if that would cause that noise or if its something completely different. It gets louder when i go over bump or pot holes in the road...any ideas??
    Yes, the knocking noise comes first and gets worse
    Eventually liquid will leak
    You should also notice uneven vehicle movement when passing over items parallel to the road wheels (speed bumps, etc)
    Clean both rear shocks
    Leave overnight
    Inspect the bottom for liquid
    In extreme cases it will simply drop to the road surface
    Feb 2011
    Bradford
    that serious eh well ill try that and im guessing replacing them is the next step if they are leaking, how much for a shocker?? do i have to buy a pair or can i get just one?? probably better changing both anyway i guess. Cheers m8internet
    You can change one, but the other won't be long behind and will part-worn so the car may respond unevenly
    Hence when replacing suspension parts, always replace identical ones across the car
    Example
    front offside spring fails, also replace the front nearside spring
    Replacing both rear shock absorbers cost me £266.49
    Half of that was paid out under warranty, for the failed one
  1. Just had my DMF replaced in ££££ shocker!!!!
    By Westy SRI in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 19:47
  2. Front shocker
    By biglee55 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2009, 08:12
  3. Tracking and Shocker hell!!!
    By Cossy in forum Handling & Braking
    Last Post: 1st June 2009, 20:12
  4. A right shocker!
    By bigknill in forum Handling & Braking
    Last Post: 14th July 2008, 08:34
  5. Bit of a Shocker, even for TFL!
    By VXR_DV in forum General Chat
    Last Post: 1st May 2008, 10:19
