Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Gearbox ident number location? Please Help!!!!
    Dunstable
    Default Gearbox ident number location? Please Help!!!!
    Hi guys, following on from previous threads I'm still looking for a solution to my cruise control problem. Basically I need to find out if the garage that fitted my new gearbox have fitted the right one or not. They are sure they have but I'm not convinced and they won't do anything to help. Anyway, I have found that the gearbox in my 1.8 vvti should have an ident of L6 and the ratio should be 4.19. I have tried looking for the ident number on the gearbox but cannot find a thing. Can anyone tell me where to find the ident number and also if there's anything else I can do to see if the gearbox they've fitted is the right one. I can provide part numbers if that helps. Many thanks!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I'll have a look when I get home bud.
    Dunstable
    Cheers rushy, you're a diamond! I have no clue about any of this and no-one I ask seems to be able to help
    scotland
    there should be a number teeped into it , jack it up and look at the side of it neer the front , should see it without having to take the wheel off . look closely as if dirty its hard to see . have a look here http://www.opel-infos.de/getriebe/f17.html
    Sep 2009
    midlands
    That link gsxrster has posted will show you pal, it may well be covered in dirt, if you put full left hand down lock you have enough room to see, it's right at the bottom facing you, mine is ao7261f17w419, I would say yours is or should be the same as mine has cruise controll aswell
    Although mine is pooped and needs to be replaced, how much did it set you back to get yours done if you don't mind me asking?
    Dunstable
    Quote Originally Posted by pokajedi View Post
    Thanks for the help so far guys, will take a look, I know this number is easy to see on mine as I've not long had the box put on and I have seen it before. The recon gearbox and a new clutch at the same time set me back around £900
    Dunstable
    Thanks ever so much for that number too mate, thats one of the numbers I was after originally, should be the same as mine as yours is pretty much the same car. 1.8vvti yeah? Don't suppose you have some of the numbers on the top too? I've attached a photo of the numbers on mine, would be interested to see if they match up with yours!! Would really be helping me out
    Sep 2009
    midlands
    Will go and have a look if I can find them pal, are they easily accesable? Mine has neally 60000 miles of road dirt lol,
    900 quid, ouch, kinda knew it was gonna cost me around that, gonna have to wait till next week untill I get paid!
    I did start a thread to ask any1 if it was possible to retrofit the 6 speed box to fit and replace the original 5 speed, but no1 thinks it possible
    Sep 2009
    midlands
    Mate the nos on mine are loads different to your picture, I have no idea what they are tbf
    What exactly happened to your box and is yours a fac recon or did they re do your old one?
    Oh and yea mines an 06 1.8 Sri
    Dunstable
    Thanks mate, the p/n in the photo's are located on the top of the gearbox, just open the bonnet and they should be there. May be covered in crap though lol, I've taken some photo's of all the numbers I can see. If anyone else can see if these numbers match to the correct gearbox my car should have that would be fantastic.
  1. boot fuse location and number ( if possible)
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 14:27
  2. boot fuse number and location
    Last Post: 24th December 2012, 13:05
  3. Engine number location (Z19DTH)
    By lee gsi in forum Engine & Drivetrain
    Last Post: 5th January 2011, 13:02
  4. 2.2 Direct Engine Number Location
    By Palmo in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2008, 00:35
  5. Gearbox Number
    By keith1949 in forum Engine & Drivetrain
    Last Post: 20th November 2007, 22:41
vauxhall vectra gearbox code
vectra c gearbox code location
vectra c gearbox identificationvauxhall vectra gearbox code locationzafira gearbox codevectra gearbox identificationwhat gearbox is in my vectravauxhall zafira gearbox codelocation gearbox code vauxhall zafiravauxhall zafira 08 gearbox identificationvectra gearbox codeswhere is the Vauxhall Zafira gearbox codevauxhall gearbox codeshow to identify astra gearboxwhat gearbox has my vectra got invectra c gearbox codeshow me gearbox number vauxhall vectrazafira gearbox idc vectra gearbox codvauxhall astra g 1.6 gearbox number location astra gearbox code location how to tell wich gearbox is in my zafiravauxhall vivaro gearbox code locationhow to find vectra gearbox number vauxhall gearbox code location
