Results 1 to 10 of 14
Thread: Something odd with my brakes...
    Chelmsford
    Default Something odd with my brakes...
    Hi guys,
    Keep getting an odd vibration in my brake pedal, but only after I've held it down slightly for a while (like braking gently when coming off a motorway) then letting go and reapplying.
    Keep finding the pedal going hard too. Oddly, if I let the vibration thing happen, it softens up again.
    Anyone got any ideas? Vacuum problem?
    Fluid has been replaced recently and fully bled. Discs are pretty new and I recently stripped and overhauled the front calipers (following MOT advisory about a brake imbalance).
    Aug 2010
    Leeds
    ABS sensor im taking a stab at, best have it checked to be sure.
    Regular Member scarydeath's Avatar
    Sep 2009
    County Durham
    It does sound like the ABS kicking in, alhough at these brake loads it realy shouldn't be!
    May 2006
    scotland
    I had a sensor that had moved slightly years ago on a Rover. In this instance, the ABS would kick in when the car was just about at a dead stop. The symptoms were you felt the brake pedel pulse very fast and the ABS light on the dash would illuminate briefly. If it were the ABS on your car, I would have expected the warning light to illuminate when the fault was being exhibited. Maybe I am wrong though.
    Chelmsford
    I don't remember the light ever coming on when the ABS was activated. Is it supposed to?
    I initially thought of ABS when the pedal was vibrating, but it only ever happened after a few seconds of gentle braking. Normally it's absolutely fine...
    May 2006
    scotland
    The light did flicker on my Rover. My Vectra I do not know, my ABS has never activated in the 5 years I have been driving it. Sorry.
    Quote Originally Posted by DNS View Post
    No, the light shows up on engine startup, then switches off
    The light indicates an error / fault
    I suggest you have all four brakes full inspected to determine where the issue is
    Chelmsford
    I'm thinking of removing the ABS fuse to see if the problem occurs with the ABS disabled...
    What does everyone think?
    Oh, and does anyone know which fuse it is?!
    By the way, does anyone know if Tech2/OpCom etc will tell me if and when the ABS pump is activating?
    Aug 2010
    Leeds
    When you start the car the ABS is checked if ok the light goes out when you start, so the pump is working.
    Chelmsford
    Quote Originally Posted by Bigtee View Post
    Yeah, but I need to know if the pump kicking in is the cause of my vibration problem...
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
