Results 1 to 10 of 14
Thread: losing boost sri 2.0t really annoying
    Worksop
    Default losing boost sri 2.0t really annoying
    it goes off switch on/off and its back again any ideas wots causing it?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Could be several things, boost sensor, hose split, lambda sensor, vacuum hose etc etc.
    Regular Member Jezzy's Avatar
    S.E
    Any spanner symbols?
    Worksop
    it were doin but not last few times only does it evey so often soon as u start back up its spot on again
    Worksop
    Anyone else?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    where in the rev range does it do this?
    Worksop
    Does not do it all the time wen it does it about 2000 upwards wen it's full boost
    Jun 2009
    South Coast
    check all your hoses for leaks and make sure none have come off, also check your spark plugs for discolouration around the ceramic.. Coils can go on these as well... did on mine..
    If you can do the paperclip test and check for faultcodes to see if you have misfire problem, i assume you not have extra smoke coming out of the back when you get this. What happen when you keep your foot to the floor, does the car judder or is it just no power like driving a n/a engine...? Just trying to get more info as so far its not really enough to give more specific answers.. a code check will be a great help..
    Worksop
    Quote Originally Posted by Caveman_nige View Post
    No codes nige seems to be getting better as it's not done it today also ordered silicone intercooler pipes changed plugs fitted scorpion exhaust seems lumpy on tick over after exhaust went on lol wen it does lose boost it's like a na engine like u said but all seems good at moment except for the lumpy tickover
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    ho many miles the car done, is the boost actuator working correctly
  1. 2.0t boost trouble keep losing the turbo
    By tomo41 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 13:25
  2. 1.9 150 CDTI losing power/boost
    By jay w in forum Engine & Drivetrain
    Last Post: 26th February 2012, 22:57
  3. losing boost pressure
    Last Post: 10th July 2011, 16:35
  4. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  5. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
