Results 1 to 10 of 13
Thread: egr
    Nov 2010
    doncaster
    Default egr
    gonna clean egr out this next week when i service the motor cdti 150 is it worth fitting that reducing plate if so any probs with it and gains etc pros and cons and where can iget parts and new gaskets from cheers
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You will get them from Fiat m8.
    Nov 2010
    doncaster
    whats pros and cons of doing it as dont want to completly blank it or do i help please
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I blanked mine completely as I had issues.
    Pros - car is more responsive and inlet manifold remains clean from soot.
    Cons - Exhaust gas temperatures are higher and put the turbocharger bearings under strain, leading to possible premature failure. And shouldn't be done on a car with a DPF.
    May 2006
    scotland
    If it aint broke don't fix it is my motto
    Aug 2010
    Derbyshire
    Quote Originally Posted by wickedwillie View Post
    Yep what he said.
    I just got myself a new gasket set and cleaned it out.
    After I did that I took the throttle body off as well and gave that a clean, that wasn't too bad.
    Worth doing both together whilst your at it.
    Result much smoother and more responsive.
    For the £4 it costs for the gaskets, worth doing every year at least.
    Mick
    Nov 2010
    doncaster
    where did you get gaskets from mick and part numbers if got them
    Aug 2010
    Derbyshire
    Quote Originally Posted by fjaimo10 View Post
    Not exactly where I got mine from, but these are the same. http://cgi.ebay.co.uk/Vauxhall-Vectr...item415ac57269
    For some reason the ebay seller I got mine from a Vauxhall dealer hasn't got any listed.
    Alternatively just type in EGR gasket into the search and a few will pop up for the 150 CDTi engine.
    Mick
    Nov 2010
    doncaster
    any how 2 on this what you clean it with mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Carb Cleaner - get it from Halfords £5.
