Results 1 to 10 of 14
Thread: Had timing belt done
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Default Had timing belt done
    Hi all as said above and while the mechanic was at it he cleaned the egr. He said it was a bit dirty. He also showed me the old tensioner and it was very worn so it's a good job I had it done now. It also feels much more responsive as well :-)
    Regular Member scarydeath's Avatar
    Sep 2009
    County Durham
    I bet it feels awesome that another thing that could go wrong, now won't!
    how much that cost you?
    I would be concerned about a tensioner being worn
    Recommendation is always to replace the cambelt and tensiors (as per the kit)
    How long had that tensioner been on the car?
    How did it compare to the other?
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    I got the belt kit and water pump and the labour cost me £160. M8internet the car has done nearly 89000 miles so I presume that is the original belt as there is nothing in the service book to say it's been done before. I don't know how it compares with the new one because I didn't see it
    Quote Originally Posted by gaz1965 View Post
    Not the new one, the other worn ones that were removed
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Oh sorry I didn't see them only the tensioner
    The other two parts are fixed rollers
    These normally exhibit more wear than the tensioner
    This suggests the cambelt was too tight, so would need to see it to compare
    The rollers should then show similar wear
    By retaining all four components it can help in the event of premature cambelt failure
    As above, I would have concern about wear on just the tensioner
    If there was wear on the tensioner, I'd hate to see what state the cambelt was in
    May 2006
    scotland
    Now you are getting him worried.
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    The mechanic that I used is a friend so he would have pointed out any major concerns so I'm not overly worried but thanks for pointing it out. I will mention it to him when I see him. Thanks for the advice m8internet :-)
    Chelmsford
    What engine are we talking here? Diesel?
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 11:21
  3. Timing Belt
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2012, 06:52
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. timing belt?
    By jaff in forum General Chat
    Last Post: 4th September 2008, 20:15
